A/C not working - help needed
Old May 15, 2007 | 10:14 PM
Vette Ed's Avatar
Vette Ed
CI 4-5-6-7-8-9-10 Veteran
St. Jude Donor '07-'09
Default A/C not working - help needed
I did some mod to the car, including a FAST Intake and a LS2 t/b.
When I turn the air cond. on the light blinks until you keep the rpm's
up. When the throttle position drops below 12% the computer shuts off the a/c. I checked the coolant with gauges and everything seems ok. Is there a something in the computer ( a setting) that I am missing .When the rpm's are up, a/c is cold and the engine idles smooth. As soon as you let off the gas and it goes to idle the a/c constantly goes off and on. The idle is set at 975.
Any suggestions and help will be appreciated...:cheers
Old May 16, 2007 | 12:54 AM
Got uid0's Avatar
Got uid0
St. Jude Donor '17
what does your outside air temp read?
Old May 16, 2007 | 06:08 AM
Vette Ed's Avatar
Vette Ed
at the time 78
Old May 16, 2007 | 07:56 AM
bluvette79's Avatar
bluvette79
do you notice a difference with auto on and auto off with a/c on. i wonder if a/c malf. would set any codes.
just thinking out loud. good luck!
Old May 16, 2007 | 08:29 AM
VinceC5's Avatar
VinceC5
did you remember to reconnect the vacuum line under the intake next to the oil pressure sending unit?
To A/C not working - help needed
