Codes P1635 And P0335 After New Engine
Old May 16, 2007 | 03:01 PM
ss2z06's Avatar
ss2z06
Default Codes P1635 And P0335 After New Engine
I just got finished installing my new motor and have two codes p1635 and p0335. I think the p0335 is related to the p1635 because the car will start for a few seconds and die. I have checked and don't see any obvious connection issues. I have 5v at the map. I don't know whats going on. Any suggestions would be great!
Thanks!
-matt
Old Aug 12, 2007 | 06:40 PM
JonLT4CE's Avatar
JonLT4CE
Thanks!
-matt
Matt:
Did you ever fix your P1635 code? THe circuit also includes the A/C pressure switch, Oil pressure sensor and the right tank fuel level sensor.
Mine was after I did a L92 Heads and Cam. I had to use the extension harness for the MAP and conversion harness for the LS2 throttle body.
Thanks,
Jon
