Manually Shifting A4
Old May 16, 2007 | 08:00 PM
jhiiidoc's Avatar
jhiiidoc
Default Manually Shifting A4
Sometimes, to keep the engine in the powerband (or just to hear the exhaust) I mannually shift my A4 and, when driving in conditions under 45 mph, I will not shift into OD. Does mannualy shifting the A4 shorten the life of the tranny? It just seems like my engine and tranny are lugging hard when the TC locks up and I accelerate without triggering the downshift.
Last edited by jhiiidoc; May 16, 2007 at 08:01 PM. Reason: needed to subscribe to the threat
Old May 16, 2007 | 08:13 PM
dw99vette's Avatar
dw99vette
From: 15 miles south from the Raisin Capitol of the World Caifornia
H E L L O anyone out there ?
Old May 16, 2007 | 08:47 PM
Rag-Top Rick's Avatar
Rag-Top Rick
Since I canyon carve and was concerned about this I called RPM Transmission for their input, they said manual shifting an A4 is not an issue providing you use commom sense, ie: banging the rev limiter, power-shifting, etc.
The only thing they said to avoid is flooring while in overdrive at freeway speeds (say aprox 70mph) which results in down-shift from 4th to 2ed, (apparently extreme shock to the trans) instead they recommended down-shifting into 3rd before flooring it so that it down-shifts only one gear!
Since these transmissions run hot even in stock form I/others recommend running a trans cooler, heat kills and a cooler is cheap insurance.
If you do a search you will find several threads on the subject.
RTR
Old May 16, 2007 | 08:50 PM
C5SteveMR's Avatar
C5SteveMR
Default tough question.
I think many factors determine your tranny's lifespan. Factors like temp, amount of brake torques etc. But vettes were meant to be driven--so go for it.
C5Stevemr
Old May 16, 2007 | 09:49 PM
Mike Mercury's Avatar
Mike Mercury
Originally Posted by C5SteveMR
.... But vettes were meant to be driven...
Old May 16, 2007 | 10:30 PM
Optimus_C5's Avatar
Optimus_C5
From: If opportunity doesn't knock, build a door. South West Florida / Livin' The Dream
St. Jude Donor '12
I also have an A4 and had some of the same questions last year. After reading several posts about it the consensus seemed to be that it's fine to do. The only caution seemed to be with downshifting. the logic was that brake parts are cheaper than transmission parts.
To Manually Shifting A4
