Broken Headlight
Old May 16, 2007 | 09:54 PM
Mudvayne387's Avatar
Mudvayne387
Default Broken Headlight
Ok , just bought a 97 Nassau Blue Yesterday , tonight i went to turn my lights on and the left headlight would not come up. Any clue what this might be ?
Old May 16, 2007 | 09:56 PM
jdmvette's Avatar
jdmvette
Night Owl for life
probably a stripped headlight gear. especially if it's OEM circa 1997...
Old May 16, 2007 | 10:51 PM
ROJ#79's Avatar
ROJ#79
Old May 17, 2007 | 11:50 AM
Blown 346's Avatar
Blown 346
You could try and raise the light yourself. There is a round rubber cap off to the side of the headlight under the hood. Take the cap off and turn it manually and see if that works.
Otherwise I agree with above. A nice set of brass gears will last the life of the car.
Old May 17, 2007 | 01:18 PM
Mudvayne387
Default Thanks
Thanks , it does go up manually
Old May 17, 2007 | 01:28 PM
SebringSixSpeed's Avatar
SebringSixSpeed
I had a similar problem w/ my 98 and just got some brass gears from Rodney Dickman's (262)835-9575 for under $100. Came w/ good instructions and gasgets and grease. Pretty easy to install yourself as long as you don't have Popeye forearms.
To Broken Headlight
