Service ABS and Traction Control??!!
Old May 19, 2007 | 04:44 AM
StiflersVette's Avatar
StiflersVette
Default Service ABS and Traction Control??!!
For the past week or so, every now and then my Service ABS and Traction Control lights will come on while Im driving. usually occurs if I hit a bump, it has been happening more often....what the hell is going on???
Old May 19, 2007 | 05:03 AM
sultan 2 ZR1 KSA's Avatar
sultan 2 ZR1 KSA
same problem help please
Old May 19, 2007 | 06:17 AM
cliff_ford's Avatar
cliff_ford
Check for error codes and post them.
Old May 19, 2007 | 06:33 AM
trussme's Avatar
trussme
Default It's your EBCM ...probably
Originally Posted by StiflersVette
For the past week or so, every now and then my Srevice ABS and Traction Control lights will come on while Im driving. usually occurs if I hit a bump, it has been happening more often....what is going on???
Some basic information on AH, TC, and ABS. In simple terms, these three systems combine data from wheel speed sensors, yaw rate sensors, steering wheel position sensors, along with brake and throttle inputs to determine what the driver wants to do and detects any lose of traction and take corrective action by pulling back on the throttle, activating brakes on individual wheels, or releasing brake pressure as needed to maintain traction.
What goes wrong
When there is a problem anywhere in the system, the computer does not know what's going on with the car or cannot respond correctly. Rather than risking the wrong response which could potentially wreck you car, the whole system is simply disabled for the remainder of the ignition cycle. At this time you will see the ABS and Traction Control warning indicators illuminated on the instrument cluster along with the following messages on the Driver Information Center (DIC):
- Service ABS
- Service Traction System
- Service Active Handling
At this point, you can safely continue to drive your car, just remember that your electronic driving aids are no longer functioning so you should adjust your driving habits accordingly.
Troubleshooting
As I said before, when there is a problem the system is deactivated for the remainder of the ignition cycle, so sometimes everything will go back to normal if you just turn off the car and restart it. If that corrects the problem, it was either a glitch in the system, a lose connection that's going to come back soon or an early sign of a future failure that is coming. Even though the system is now functional it is still beneficial to continue to trouble shoot. The history code should give you a good idea of what to check
The next step is to see where the fault is. If you have several different codes write them down, clear them, and see which ones come back the next time you start the car. At this point, I'm betting that the codes point to the EBCM.
Electronic Brake Control Module
The most common code for the EBCM is C1214 - Sol Valve relay Contact or coil CKT Open. This code is set when the system voltage is less than 8 volts for 0.23 seconds.
.....at this point you need to PM me your email address, as my file with pics is rather lengthy on how to fix this problem....I will email it to you.
At worst, you may have to have your EBCM rebuilt ($150. + UPS)....I have that info included.
Let me know if I can help! Bill
To Service ABS and Traction Control??!!
