Vette Won't Lock All The Time!?!?
Old May 19, 2007 | 07:25 AM
Vette Girl's Avatar
Vette Girl
Cruise-In IV Veteran
Default Vette Won't Lock All The Time!?!?
When I lock my Vette (withe the key fob), the drivers side won't lock all the time. I was previously told that I may need a BCM. Is this the case and if so, what is a BCM and how does it get installed? Please help because this is driving me crazy!
Old May 19, 2007 | 09:40 AM
ZO6vettepilot's Avatar
ZO6vettepilot
Try replacing the battery in the key FOB first. They don't last forever.
If you have already replaced the battery recently, pull it out and clean the contacts in the FOB and the battery surfaces with a pencil eraser, then wipe with a dry cloth or paper towel. Try not to touch the contact surfaces with your fingers as you replace the battery, the oils and moisture will cause oxidation and poor contact after several months.
Also try your second key FOB, it that one works, then the car is probably not the problem. Always try the simple and less expensive parts or components first unless there is a specific test procedure that can absolutley identify the failed component. Would be a shame to replace an expensive BCM only to discover the FOB battery was weak.
Old May 19, 2007 | 01:44 PM
white90conv's Avatar
white90conv
If it is not in the FOB, it is most likely a relay in the door control module which is in the door. This is not the BCM. If the other functions on the remote work, this is most likely your problem. You can either replace the door control module or replace the relay. Search for other threads on this subject.
Old May 19, 2007 | 01:46 PM
Vette Girl's Avatar
Vette Girl
I don't think it's the key fob since it always locks my passenger door. I'm just having trouble with the driver's door. But I will pull out the battery and clean it. Thanks!
Old May 19, 2007 | 01:47 PM
Vette Girl's Avatar
Vette Girl
I'll try that. Thanks!
Old May 19, 2007 | 03:32 PM
Greg_E's Avatar
Greg_E
Here's the link to repairing the door lock/ window module.
http://forums.corvetteforum.com/show....php?t=1606865
Probably under $10 including the shipping.
You can solder a new relay in the circuit board which will be way cheaper than taking it to the dealer.
The Digi-Key part number for the door relay is 255-1240-ND and you can find it at www.digikey.com.
Old May 19, 2007 | 04:48 PM
Z06ufgrad2002's Avatar
Z06ufgrad2002
I had a similar problem with my car. I intermittantly lost all electrical function in the drivers door. Sometimes it would work fine other times completely dead.
I grabbed the accordian rubber thing that runs from the door to the frame and immediately it started working again.
Talked to my local tech about my symptoms and he stated it was most likely the wiring harness. I pulled the accordian thing off and inside there are two wire groups both with a connector on them. I took both apart and one connector had a small terminal that looked bent or did not appear able to produce a good contact with it's male counterpart. I pulled that connector out of the housing and bent it back as close to the others as possible so it would make better contact. So far the problem has not come back. It's only been a couple of days but, I am hopeful it is fixed.
I would look at that connector before replacing the door control module. They are quite expensive.
Old May 19, 2007 | 07:33 PM
rapid robert's Avatar
rapid robert
I had the same problem. The drivers door wouldn't lock or unlock. Ordered the relays from DiGi-Key. They were $1.42. I ordered 6 just to be safe.The total was $14.34 shipping and tax.
Replacement was very easy. Just follow the inst in the post above. Just make sure you have a soldering iron that gets hot enough to melt the solder to take out the old ones. You also need a solder sucker. I used a 45 watt with a pencil point. It worked but I think a little more wattage like 75 would have worked better. Good luck Bob
Old May 20, 2007 | 07:07 AM
Vette Girl's Avatar
Vette Girl
Thanks! This helps out so much!
Old May 20, 2007 | 07:08 AM
Vette Girl's Avatar
Vette Girl
Thanks! I'll try this first to see if this is the problem. Hopefully it's as simple as this! I'm keeping my fingers crossed!
Old May 20, 2007 | 07:10 AM
Vette Girl's Avatar
Vette Girl
I'm glad I'm not the only one to have this problem...unfortunately. Thanks a lot for your help!
Old May 20, 2007 | 07:20 AM
trussme's Avatar
trussme
I had same problem...stealership replaced it n/c under "good will policy"
Old May 20, 2007 | 08:08 AM
rws.1's Avatar
rws.1
before you desolder... remove the circuit board and re-insert it... sometime it is just a loose connection .. that has happened because of bumps and slamming the door closed...
To Vette Won't Lock All The Time!?!?
