Tfs + Roller Rockers + Cam?
Old May 19, 2007 | 01:41 PM
427CPE's Avatar
427CPE
Default Tfs + Roller Rockers + Cam?
If had to choose a cam for this setup, what would it be? I'm thinking
228/232 on a 112LSA or there about.
If you choose a cam > 230 degrees intake duration, please state your theory for this. What should the spread be on the intake/exh durations for these heads? I do plan to run a long tube header.
Old May 19, 2007 | 02:11 PM
zeevette's Avatar
zeevette
A couple of questions, first. Do you have a 427, or a 346? What are your goals for your car? I have the exact combo you enquire about, so can probably give you an informed opinion.
Old May 19, 2007 | 02:54 PM
427CPE's Avatar
427CPE
I am just starting to modify a 02 Z06. 0z 700 clutch on the way and will be using halltech stinger. Next up is heads/cam/exhaust or maybe just cam/headers. The engine is the stock 346. The 427 was my Mustang. I want max power < 6500rpm. Car is weekend warrior only. It will get drag raced but is a street car. Probably have cats.
I am particulary interested to know of comparions between say a
224/228 on a 112 COMP CAM and a 232/240 112 COMP CAM.
I suspect the extra duration is a waste, but would love to hear about real time usage.
I have used TFS heads on my Mustang and they were serious power makers. Can't wait to find out if the LS versions are worth it.
Old May 19, 2007 | 04:52 PM
electronbluec5's Avatar
electronbluec5
I have been running the TFS heads for about 4000 miles now and I have been very happy with their performance. I also have a comp cam from Vengeance that is a 224/228 on a 113lsa. It made 470 whp with all of the supporting mods + a ported Fast 90/90. I think you will be very happy if you go this route. The car makes good power down low but it really wakes up at about 3500.
Good Luck
Greg
Old May 19, 2007 | 05:30 PM
427CPE's Avatar
427CPE
Which head gaskets did you use? Did you have a fit problem at all w/stock valve covers, TFS and Harland Sharp Roller Rockers? Wonder what the FAST intake gained. Also, what CC head is yours? I'm thinking I want a smaller chamber to increase compression.
Old May 19, 2007 | 08:42 PM
electronbluec5
I am really not sure what gaskets were used but I know the final CR came to 11.4:1. I did not do the install myself but I know there was significant grinding done on the valve covers to make them fit. Yes, I have the Harland Sharp RRs. The heads are 64cc chambers but a lot of the guys making 500+rwhp had the 59cc chambers. A similar car to mine made 25whp at peak and about 20whp throughout the band with the Fast 90/90 when installed on the dyno. It was pretty impressive.
Old May 20, 2007 | 12:06 AM
427CPE's Avatar
427CPE
How many degrees advance ground in the cam and is it dialed straight up?
Old May 22, 2007 | 04:37 PM
427CPE's Avatar
427CPE
electronbluec5,
Ok, nuff said. I ordered up the TFS HEADS + CAM + HS RR.
I'll post a 1/4 MPH when avail.
Old May 22, 2007 | 06:16 PM
tblu92's Avatar
tblu92
St. Jude Donor '13-'14-'15
Hello--It says you are from Calif ----Do you have tpoass Smog ??? If so that will really dictate what you can run for a camshaft---The cam you've chosen probably will not pass---I am in Calif also--I passed with a .221/.221 @ 114---But I think you could go a bit larger and still pass--say around a .224-228 @ 114---I don't think a 112 LSA will pass at all-But if you aren't concerned with smog--them Id use the method of study and pick a camshaft for your combunation--then go 1 bigger !!!
Old May 22, 2007 | 06:23 PM
427CPE's Avatar
427CPE
The cam I will be using probably won't be good for the sniffa if you know what I mean. Come smog time, I'll do some "work" to clean things up. Go 1 bigger,
Old May 22, 2007 | 08:23 PM
zeevette's Avatar
zeevette
I did do all my own installation, and I used GM MLS gaskets, and my heads were shaved to 61cc chambers. I didn't have any problems with the HS rocker arms, and stock valve covers. No grinding. My final SCR was 10.95-1 and the DCR was 8.5-1 with my Crane cam@ 228/232 @112+5, and .600/.600 lift. As you probably know, the design of the TFS heads allows more PTV clearance. I have lots of power down low, and midrange is amazing. I didn't care too much about peak power, but this combo screams all the way to 7000, so I guess I'm not missing too much. We only get 92 oct. here, but the tuner said theres no indication of any KR. Traction, however has become a problem.
Old May 23, 2007 | 12:47 AM
427CPE's Avatar
427CPE
My setup will be similar w/GM gaskets, 61cc heads, and a 112 lobe. How bad was it to drop the steering rack?
Old May 23, 2007 | 12:43 PM
zeevette's Avatar
zeevette
Just alot of work, but not too bad. A couple of skinned knuckles, as per my usual.
Oh yeah, be careful of the aluminum crossmember; mine has sharp edges from metal flashings in the castings.
To Tfs + Roller Rockers + Cam?
