Radio Problem
Old May 19, 2007 | 02:39 PM
cleo299's Avatar
cleo299
Default Radio Problem
I need help please. I have a 99 vert. The power antenna died - i.e the motor stopped working. I bought a new assembly (through GM direct parts). I took the old one out and put the new one in - how hard could this be?
Prior to the change, everthing worked fine - Sirius, FM, and the CD player. Now, nothing works fine. The new antenna won't raise when the radio is turned on; FM and the CD player can barely be heard at full volume; no Sirius sound at all.
It looked so simple!
I took the new one out and put the old antenna assembly back in - no change, everything still would not work.
I checked the codes - no codes of any type.
Any suggestions would be much appreciated.
Old May 19, 2007 | 03:19 PM
chris308's Avatar
chris308
could be your head unit, i think i read were some of them have been known to go bad.
