I just bought a 98' vette and the check engine light came on and stayed on. The system gave me the following codes. Should I not worry about them? The previous owner put headers on the car and this may jack with sensors...
Could be a few things, all related to the headers...
* Melted O2 wires (quite possible if the wires have come into contact with the headers)
* Bad O2 sensors (leaded gas will do this)
* Exhaust leak (before the O2 sensor bung)
Melted O2 wires or an exhaust leak are the most likely causes, IMHO.
It WILL hurt the car to drive with a dead front O2, fuel trims will get WAY out of line. Sensor #1 refers to the front and has nothing to do with high flow vs regular cats.
Disregard FRCTony's post. He was thinking you had a sensor #2 issue.
The car won't know what AFR it is running, thus it could be dangerously lean, or pig rich. I suspect the computer will dump fuel into the engine as a result, which will rob power. However, it could stay running really lean and melt pistons.
Sorny
Or it could be smart enough to know that the O2 sensor is not switching and run open loop speed density.
There are more than a few folks running without O2 sensors.
