PAINTING BRAKE CALIPERS
Old Oct 22, 2001 | 06:10 PM
troy'sC5's Avatar
troy'sC5
Default PAINTING BRAKE CALIPERS
i am going to do my brake calipers today and was wondering if everyone is
painting around the CORVETTE LETTERING or if you are painting the whole
thing and then taking off the red paint. also, are guys painting the brake
pads red also. i ordered the paint from mid-america. is there a problem
with the paint drying even if the paint is in the can tightly. please let me
know a.s.a.p. because i would like to do this today.
Old Oct 22, 2001 | 06:28 PM
CMilVette's Avatar
CMilVette
Default Re: PAINTING BRAKE CALIPERS (troy'sC5)
I painted the lettering, and then sandpapered it back down to the silver.
Some also paint the pads, but I do not prefer that look, so I only painted the calipers
Good luck! :cheers:
Old Oct 22, 2001 | 06:35 PM
BatMobile's Avatar
BatMobile
Tropical Moderator
Cruise-In 1-5 Veteran
St. Jude Donor '03-'04-'10-'11
:cool:
:yesnod:
Neill
Old Oct 22, 2001 | 06:37 PM
George Cooper's Avatar
George Cooper
Sand the letters using a small piece of ~400 grit on flat backing after the paint is dry. The paint will last ~4 hrs if very tightly capped in small container after mixing.
Old Oct 23, 2001 | 02:33 AM
SILVER 97's Avatar
SILVER 97
I removed the pads, rubbed vasoline on the letters, and sprayed the whole caliper. Then just scrape off the vasoline-paint with you fingernail.
:cheers:
Old Oct 23, 2001 | 02:42 AM
GSCARR's Avatar
GSCARR
cancel your order from mid america. just buy engine paint spray from and auto parts store for $5.00. the "ford red color" is a perfect shade. painted mine 4 months ago and it still looks like new.
Old Oct 23, 2001 | 09:51 AM
C5Longhorn's Avatar
C5Longhorn
Default Re: PAINTING BRAKE CALIPERS (GSCARR)
I used Rustoleum and then just sanded the paint off the letters. Very easy job.
Old Oct 23, 2001 | 01:17 PM
Sales@MVPAutoParts.com's Avatar
0Sales@MVPAutoParts.com
Former Vendor
Same here :D
Old Oct 23, 2001 | 01:39 PM
hmert's Avatar
hmert
I used high temp engine paint (1200 degree F) from Auto Zone. Sprayed it in a cup and painted the calipers (calipers only, not the pads or retainers) with a small brush. It took several coats (at least 4) over several days. I then scraped the dried paint off the letters with a knife.
Good luck. The results are worth it.
Old Oct 23, 2001 | 07:03 PM
Umrswimr's Avatar
Umrswimr
From: Overwhelmed as one would be, placed in my position.... DFW, TX
St. Jude Donor '05
Did you guys remove the caliper if you spray painted them? I'd be worried about getting paint on things that wouldn't look good in red... You can mask it off, but what a pain...
Old Oct 23, 2001 | 07:14 PM
Godspeed's Avatar
Godspeed
Senior Member
Cruise-In III Veteran
Cruise-In IV Veteran
I bought DupliColor high temp engine paint at O'Reilly. Then I sprayed it into a can and painted the calipers with a small brush including the letters but not the pads. I put about 5 coats on it over a 2 day period. Then I took a standard razor blade and scraped the paint right off the lettering, no problem.
-Jeremy
To PAINTING BRAKE CALIPERS
