C5 Tuners Step in
Old May 21, 2007 | 01:25 PM
vette dan's Avatar
vette dan
Vette Dan
Default C5 Tuners Step in
OK quick question.
Just what is or does turning off torque managment do if you get a tune on an A4????
What should shift points be changed to with a 2.73 rear end??
Autocross and drag every once in a while.
TXS
Old May 21, 2007 | 01:48 PM
Last C5's Avatar
Last C5
Assuming that you are talking about a dyno tune, you have to turn off the traction control or when the wheels start spinning the dyno drums the engine will reduce power thinking that you are spinning.
Old May 21, 2007 | 02:30 PM
edcmat-l1's Avatar
edcmat-l1
Torque management reduces power momentarily BETWEEN SHIFTS. Supposed to help your trans live a longer, healthier life. You can turn it off completely, or change the amount of reduction.
Old May 21, 2007 | 07:14 PM
Mike Mercury's Avatar
Mike Mercury
yep
looking at the graph, the top halfs blue line is engine rpm. Notice the A4 WOT shift happening in the center... about 5600rpm.
Then look directly below at the botton half. In that graph the blue line is timing. Notice that during the WOT RPM wind-up, the advance is around 26 to 28 degrees. Then at the shift point, timing is pulled... so much so that it actually is in the retard (minus) region
Old May 22, 2007 | 08:32 AM
vette dan's Avatar
vette dan
Vette Dan
TXS Mike the graph shows a lot. As always the forum is the best source for info.
Old May 22, 2007 | 09:32 AM
JeffC5's Avatar
JeffC5
From: Edmond, OK...One of the first rules of online forums: If you don't like what is said but can't refute it, attack the poster.
You need to talk to Jim at SW tuning. Give him a call 728-5044
jeff
To C5 Tuners Step in
