Recommended O2 sensor--what brand?
Old May 21, 2007 | 01:37 PM
500hp's Avatar
500hp
Default Recommended O2 sensor--what brand?
I think I need to replace my passenger side (primary) Oxygen Sensor. They very well could be the originals, but I am still going to try to get by with replacing just the problem Sensor.
What is the popular replacement for a Z06 with TSP cam & headers, no cats & no rear 02s?
I have used Bosch in the past, on my LT1 C4 and non-performance cars, but have heard mixed results on C5s.
My TSP headers have them touching each other, so something with a smaller body, than stock, would be nice (but not mandatory).
Thanks, Joel.
Old May 26, 2007 | 02:29 PM
500hp's Avatar
500hp
Denso? Bosch? Others?
What kind does GM use?
Old May 26, 2007 | 02:36 PM
Billdog350's Avatar
Billdog350
I just put two brand new bosch 02's in my LG Street headers (before cat position, using the after cat 02's with longer wires) and they're already bad. They lasted not even 6 months and my tune was dead on (approx 12.9:1 at WOT and LTFT's are all around -1 to 0 in part throttle).
I'm going to dry some AC Delco's next time. I took out one delco thinking it was bad a while back, but it ended up being fine...one bank of my car after the cam is running richer than the other regardless of what O2 is in there. I have seen posts about this, I guess its a somewhat common occurance.
So far, it looks like the delcos have better heaters and throw less codes....JMO.
Old May 26, 2007 | 06:34 PM
Dope's Avatar
Dope
Resident moron
Just buy stock ones from GM, you can't save enough money to make it worth buying something else, honestly.
Dope
Old May 26, 2007 | 07:00 PM
nlreb54's Avatar
nlreb54
I used GM on my 98 after headers and cat install. No codes now.
Old May 27, 2007 | 05:42 AM
SunDevil C5's Avatar
SunDevil C5
Only use stock gm sensors. I changed one sensor on my last car with headers and had to replace them all eventually because the one was different. When they're 120 a piece I'd rather only do this once.
Old May 27, 2007 | 09:23 PM
berryj's Avatar
berryj
Wow, $120 is very steep. Next time buy them from GM Parts house for $50 bucks or so for the front O2 sensor.
Oh, love your avatar! I'd definitely vote for Chuck over the other clowns any day.
To Recommended O2 sensor--what brand?
