Disabling Power Windows
Old May 21, 2007 | 01:58 PM
SmoothFRC's Avatar
SmoothFRC
Default Disabling Power Windows
I wanted to disable my power windows....... just for a short period of time, Is it as easy as pullin the fuse, or will other things not work - like gauge cluster, etc...
Someone mentioned to me before that the windows were tied to the cluster, but i was not sure if this was true...
Any input would be greatly appreciated.
Old May 21, 2007 | 02:19 PM
SilvaDragon's Avatar
SilvaDragon
Just double-check your owner's manual for the fuse blocks to
see what's connected to the window fuses. You should be able
to pull the fuses with no serious problems. If you go to use the
windows, it will probably store codes, but that's about it.
Old May 21, 2007 | 05:00 PM
SmoothFRC's Avatar
SmoothFRC
Found the fuses... but didnt need to pull them anyway..
Thanks.
To Disabling Power Windows
