traction control....abs serice light
Old May 21, 2007 | 04:45 PM
vet777's Avatar
vet777
Default traction control....abs serice light
service tractioncontrol and abs light came on ,what would cause this?c5 with 18700 miles. just got caught in the rain , brakes may have got wet.
called chevy service advisor clueless. said maybe a sensor?
thanks.
Old May 21, 2007 | 06:22 PM
Blown 346's Avatar
Blown 346
Sensors could be dirty which can sause the light to come on. Also low brake fluid.
Old May 21, 2007 | 07:12 PM
trussme's Avatar
trussme
Default IT may be your EBCM...
The Basics
Let's cover some basic information on AH, TC, and ABS. In simple terms, these three systems combine data from wheel speed sensors, yaw rate sensors, steering wheel position sensors, along with brake and throttle inputs to determine what the driver wants to do and detects any lose of traction and take corrective action by pulling back on the throttle, activating brakes on individual wheels, or releasing brake pressure as needed to maintain traction.
What goes wrong
When there is a problem anywhere in the system, the computer does not know what's going on with the car or cannot respond correctly. Rather than risking the wrong response which could potentially wreck you car, the whole system is simply disabled for the remainder of the ignition cycle. At this time you will see the ABS and Traction Control warning indicators illuminated on the instrument cluster along with the following messages on the Driver Information Center (DIC):
- Service ABS
- Service Traction System
- Service Active Handling
At this point, you can safely continue to drive your car, just remember that your electronic driving aids are no longer functioning so you should adjust your driving habits accordingly.
Troubleshooting
As I said before, when there is a problem the system is deactivated for the remainder of the ignition cycle, so sometimes everything will go back to normal if you just turn off the car and restart it. If that corrects the problem, it was either a glitch in the system, a lose connection that's going to come back soon or an early sign of a future failure that is coming. Even though the system is now functional it is still beneficial to continue to trouble shoot. The history code should give you a good idea of what to check.
The next step is to see where the fault is. If you have several different codes write them down, clear them, and see which ones come back the next time you start the car. At this point, I'm betting that the codes point to either the EBCM or the wheel speed sensors. We'll get to the wheel speed sensors later, for now, let's get to the EBCM.
Electronic Brake Control Module
The most common code for the EBCM is C1214 - Sol Valve relay Contact or coil CKT Open. This code is set when the system voltage is less than 8 volts for 0.23 seconds.
PM me your email address & I will email the complete How To Fix It file with pics.... Bill
Old Feb 2, 2014 | 04:03 PM
lkoochel@yahoo.com's Avatar
lkoochel@yahoo.com
2nd Gear
Default EBCMrepair information
thanks larry
Old Apr 28, 2014 | 02:38 PM
lkoochel@yahoo.com
2nd Gear
Originally Posted by trussme
The Basics
What goes wrong
- Service ABS
Troubleshooting
my email is lkoochel@yahoo.com
Old May 5, 2014 | 10:44 PM
tpr60's Avatar
tpr60
trussme, I just bought a 03 zo6 and have the abs dash light on. Pulled codes for module #28, u1301h and c1214h can you help me with the how to fix pictures and text file??
Thanks, Bob T
Old May 6, 2014 | 09:08 AM
3boystoys's Avatar
3boystoys
thanks.
What did you expect them to say over the phone with no diagnostics at all on your part?
Old May 6, 2014 | 10:08 AM
Smoken1's Avatar
Smoken1
[QUOTE=tpr60;1586831559]trussme, I just bought a 03 zo6 and have the abs dash light on. Pulled codes for module #28, u1301h and c1214h can you help me with the how to fix pictures and text file??
Read the Stickies ...Bud
Old May 6, 2014 | 12:34 PM
guido7834's Avatar
guido7834
I had same intermittent problem. I cleaned the sensors when I had my wheels off to polish, hasn't come back in over a year.
Old May 6, 2014 | 01:23 PM
Cowboy26a's Avatar
Cowboy26a
Code 1214 is the relay in the EBCM. Time to send it off for repairs. It will happen more often in the future. Mine only had 39,000 miles and threw that code twice.I removed it and sent it to ABSfixer and all is well. Car now has 45,000 miles on it and no re-appearing codes.
To traction control....abs serice light
