Is this normal wear?
Old May 22, 2007 | 06:59 PM
DRIVER456's Avatar
DRIVER456
From: NY- 2013 Corvette Challenge Champion-2013 Index Combo Champion 2015 CC/MM Champion
St. Jude Donor '07
Default Is this normal wear?
You can see the wear marks in the center of the lobes.It only had about 4k miles on it.
Old May 22, 2007 | 07:10 PM
SpeedyZ's Avatar
SpeedyZ
Hard to tell from the photo but it don't look good. How does it feel? Is the marks smooth? If there is no pitting on either the cam or lifters your probably OK and it is probably normal. But if it is rough or pitted then that wouldn't be good.
Old May 22, 2007 | 07:15 PM
Z06ufgrad2002's Avatar
Z06ufgrad2002
My OE cam had more miles on it that yours and mine did NOT have distinct wear marks in the center of the lobes.
Old May 22, 2007 | 07:17 PM
DRIVER456's Avatar
DRIVER456
St. Jude Donor '07
Yea it is rough and kind of pitted.That was in my old motor anyway,I was just curious.Good thing I didn't put it in my new motor ..................Paul
Old May 22, 2007 | 07:20 PM
DRIVER456's Avatar
DRIVER456
St. Jude Donor '07
My OE cam was in great shape.That was an after market cam.I was going to put it in my new set up,But my gut instink said NO and of course the wear marks ................Paul
Old May 22, 2007 | 10:14 PM
SpeedyZ's Avatar
SpeedyZ
If it is pitted I would run from it! Once pitted the wear rate is escalated very rapidly. Sounds like the cam was not harden correctly. Hard to tell from the photo but I found it odd to have what looked to be marks only on the top and ramps but none on the base circle. What brand cam is that? Have you talked with the manufacture?
I wouldn't run those lifters on another cam either. Good chance they too are pitted now.
To Is this normal wear?
