Stall & MPH
Old May 23, 2007 | 11:05 PM
JT Metal's Avatar
JT Metal
St. Jude Donor '12-'13
Default Stall & MPH
typically, going from stock stall to 3200 gives (avg.) .4 in quarter mile but what's the effect on mph. also two vettes line up from a roll (same cars) wouldn't the non stall car be faster at higher speed due to the slippage of the 3200???
Old May 23, 2007 | 11:17 PM
tblu92's Avatar
tblu92
St. Jude Donor '13-'14-'15
I don;t think so--but don't know for sure--I think the TCC would catch up at higher RPM's and the speed would be the same--I have a table on my data-logger that reads TCC slip--I'll have to log some runs and compare it to my buddies car with a 3000 yank---
Old May 24, 2007 | 08:21 AM
nj02vette's Avatar
nj02vette
From: Marlton. Increasing performance one speeding ticket at a time! NJ
No, because at high speeds, they both lock-up and there is no slippage.
Old May 24, 2007 | 10:39 AM
aleadfoot's Avatar
aleadfoot
Typically convertors are lighter than stock 20 lbs engine has less load. Therefore I bet 3200 stall wins
Old May 25, 2007 | 03:37 AM
tblu92's Avatar
tblu92
Less rotating mass would generate a few more HP of course--but I think the comparison he's asking about is stall vs. non stall and not taking anything else into consideration---for comparisons sake if they both weighed the same--it wouldn't make any differenence--
Old May 25, 2007 | 10:58 AM
123sugey's Avatar
123sugey
Dig
aftermarket convertors can have more " slip " than stock ones in 3rd gear. I've run several convertors over the last few years and found the higher the stall the more the slip ... less mph i get in the quarter.
I am changing my 5000 stall convertor next week and installing a 3800.
Old May 25, 2007 | 11:50 PM
1965imp's Avatar
1965imp
Please correct me if I am wrong. My 3200 Yank "LOCKS UP" at 45mph and shouldn't change your mph after lock up.
Old May 26, 2007 | 01:31 PM
tblu92's Avatar
tblu92
The lock-up MPH of your converter is a seperate table in the ECM that is programable--It doesn't matter what stall you have in the car the TCC "apply" table dictates when the converter locks up-it doesn't care what converter is installed----As far as having a 5000 stall having less MPH in the 1/4---I've only seen high HP engine applications in the 750-1000 range that use such an outrageously high stall--sounds like a mis-application--even modded cars with super-chargers have about a 3200-4000 stall-------Also when racing the converter remains "unlocked" at WOT -with a stall of 5000 you aren't giving the converter enough time to catch up to the engine speed probably accounting for the lower MPH
Old May 26, 2007 | 01:46 PM
MR496's Avatar
MR496
Default Converters
I am a veteran Automatic Transmission Builder and have built everything high performance that there is. All that the torque converter is made to do in dragracing is to get your engine up to its peak torque output right off the batt. Under cruising applications the lock-up type torque converter normally would lock in OD at 47 mph. Under full throttle conditions though the converter doesn't lock up till u let off the pedal a little. To enlighten you a bit on Torque Multiplication Physics, The IDEAL setup would be a torque converter that would suddenly bring your engine to peak torque rpm off the line and keep it there all the way down the 1/4 mile. Thus, the use of multiple clutches in top fuel/funnycar the person that sets up the clearances in the clutches set this to lock-up more and more while going down the track.
The trick here is to not make lock up too much off the line and not lock up all the way while going down the track.
Thus there is never too much power, (as demonstrated by funny and top fuel) just not nearly enough traction.
Mike
Old May 26, 2007 | 02:12 PM
tblu92's Avatar
tblu92
Then why are you changing the 5000 to the 3800 ???????
I know what a converter does--perhaps you mis-understood what I was trying to say--You were talking about losing MPH with the 5000 stall vs a lower stall--that was the only issue i addressed to you--don't know why you chose to give me a lesson on converters--perhaps to avoid the issue of your mistake on converter choice--
Just so you know I am a profesional tuner and the TCC lock-up table is commanded by TPS position vs mph--A stock Corvette table from 80% TPS on is set to 255 mph--so it will not allow a lock-up less than 80% tps and it works together with the TCC un-lock table which is set at 100% TPS to unlock the TCC when flooring the throttle so it will not lock at any speed as long as it is at WOT---No need to be a smart ***--just admit you made a mistake with the 5000--There are more issues in choice of stall than just getting into the power band--as you found out going too high loses MPH at the big end---
Old May 26, 2007 | 10:58 PM
1965imp's Avatar
1965imp
Is it true then that when you have your car Dynoed they will program the lock-up out which will show less HP at the wheels? sorry for the hi-jack
Old May 27, 2007 | 09:53 AM
yankeevetteconvert's Avatar
yankeevetteconvert
I am assuming that you are talking about trap speed in your first question.
If you choose the proper TC your trap speed will go up. Most higher stall TCs have better efficency above the stall speed. If you look on the Yank website you can find a plot of this. Their TC has a 97% efficency and thus puts out more HP to the wheels at high RPMs than the stock TC.
The answer to your second question is no for the same reason.
Remember the slipage you are talking about takes place only up to the stall speed.
I gained 2mph in trap speed when I installed my TC.
Old May 27, 2007 | 10:42 AM
C5XTASY's Avatar
C5XTASY
I believe some do, intentionally, and some don't. I have read posts where people have said that a locked converter on the dyno is very hard on the converter and transmission. However, anyone reading anything on the Forum had best filter the info, as much of what people say on here is , so, I don't really know if this is true. When I had my Yank SS3200 installed I had the car redynoed. For whatever reason, the converter wouldn't lock up on the dyno. It operates fine on the street, however. I gave Yank a call and asked them what the rwhp difference would be between a locked and unlocked converter at WOT at peak power. They told me 20-30 rwhp, with the locked number being higher, of course. If anyone has some definitive numbers where they actually tested this, I sure would like to hear about it.
Ed
To Stall & MPH
