Cheapest Route for HP. HC/Headers or FI
1. What is the highest HP I can safely run on a stock driveline in a MN6?
2. What is the cheapest way to get there, HC and headers or FI? If HC route is cheaper would I need headers to reach max safe HP?
3. Going the cheaper route how much will it cost me? I'll have a shop do the work as I don't have time.
I've read lots of posts doing searches but haven't found these questions answered in a single post.
Should mention car is 80% street use, 20% track. Track use is road course, no drags.
Thanks in advance.
Rick
IMHO since you like RR stick to the HC with your mn6. You can easily achieve 450-500 rwhp which is plenty for RR and also alot of fun on the street.
Yes you should do headers with HC and do not be surprise if your stock clutch needs to be replaced in the future (this would be true based on power level not FI or HC).
I have 3 years of RR on my ECS HC car and about 50 1/4 passes so reliability is there too.
of course if you are RR you should also change to a dewitts radiator with oil cooler. plus maybe upgrade brakes, suspension oh nevermind the list never ends.
I realize this doesnt exactly answer your post, but in the end the cost of HC vs. FI is close so why not go with the setup that is more suitable to how you drive?
2. I think H/C is hands-down the cheapest way to add power on a stock engine, but I think you can go a lot higher with FI on a 346. A do-it-yourself H/C job can cost between $4,000 and $6,000 depending on what heads/parts you buy. I did mine for around $4,400 with a tune, using budget heads. I went with a fairly mild cam and am at 410whp. You can get a good 450whp with a set of AFR's and a mild-mannered cam without too much lope(LG's G5X1E cam 228/232 on a 115 with AFR's has repeatedly hit 450whp), and another 20 with FAST 90/90. I think a FI is going to run at least $6,000 plus tune on the low-end, unless you are buying used.
3. Mostly covered above, except figure somewhere around $1,500 to $2,000 for an install on either FI or H/C. My tuner quoted me $1,600 to install my H/C package, and quoted me $8,200 installed and tuned on a $6,300 supercharger. If I would have used my tuner for an install, the supercharger would have netted me about 480whp for $8,200, and my package now would get me 410 for about $6,000. I just couldn't rationalize $2,200 for another 70whp (although I'd love to have 70 more whp).
I think if you are on a budget, and will settle for 410-450whp, H/C will save you some bucks. If you really want to squeeze a ton of power and still have really nice street manners/idle/etc, and you don't mind dropping the cash, FI would be my preference. I just didn't want to dump that much dough...
Enjoy, but understand this never ends.....
Last two sentences sum it up
regardless of which one you do, there is always something else that comes with it. Once we cross this line of power, the clutch comes, then the drivetrain, ect, ect.
Happy modding
In terms of bang for the buck you might be better off going FI. I would look into a used centrifugal supercharger such as procharger, vortech, etc. A good used complete kit can be had for about $3,500. You should easily be able to produce 450+ rwhp with stock exhaust system, although I would suggest gettinga used Ti exhaust system (about $450) to open up the exhaust a bit. Make sure you get the newer brackets like what ECS makes so you don't have belt problems. You will also need a restrictor plate to limit boost or you will not have a motor for long. Get it installed by a competent tuner like ECS, A&A, etc.
Unless you put your foot into it the car will be like a stock car, which will give you excellent streetability. When you put your foot into it, you will take off like a jet.
If you get a chance might want to see if you can get a ride in a HC and supercharged car to see what they are like.
you'd be spending about the same amount of $$ to do that with the heads/cam route, and most likely wouldn't see those Torque numbers
the blower could easily support 700rwhp plus with a forged motor later on down the road
give me a call on Monday, we can go over the details
It seems to me there are two major areas of concern: losing a piston and breaking something in the drivetrain.
The latter is more a matter of how well you hook and how hard you drive than anything else. You can dump the rear out of one of these cars with a dead-stock LS-1 if you dog it hard enough. There are also guys running 600+ rwhp on stock MN6 drivelines with no troubles. Note that they are not drag racing every weekend on ET Streets, nor powershifting every gear.
As to dropping a piston, that is fairly common on stock shortblocks combined with N2O or turbo/supercharging. The stock pistons are simply not designed for this. Run a little lean, or a little too much spark advance, or get a tank of sub-par gas, and you melt the ring land (usually on #7) and that toasts the piston and often the block, etc.
The general consensus might look something like this: for an all-stock MN6 driveline, avoid anything stickier than good street tires or maybe DOT roadrace tires. Don't powershift. Don't drag race it every weekend. If you do that, you can have good driveline life up to around 500, maybe 600 rwhp. If breaking things would cause great financial pain, better stick to 500.
Clutches are an issue even with the stock engine. Figure on replacing it sooner or sooner.
As to the engine, certainly FI is cheaper for "the most" power - until you lose #7. FI is not cheaper if you have to buy the FI unit and a forged shortblock. Especially if you do those things out of order and have to pay for labor twice. To be fair, there are guys out there who have multi-10k miles on their stock-shortblock FI cars. But, they tend to be pretty conservatively tuned, and they tend to not beat on them. Once you get much over 500 rwhp, 550 at most, on a stock shortblock, the clock is ticking. Again, if replacing a blown engine would not be financially traumatic, cool deal. Otherwise, I'd think carefully.
Another consideration is that you mentioned road racing. NA cars are generally strongly favored over FI cars for road racing. Reasons are that an NA car can make all the power you can use, and a NA car tends to have more predictable and controllable power delivery. But the biggest reason is that FI C5s tend to have serious cooling issues when road raced. This just leads to more expense. This is not to say that an FI car can't work for road racing. Just that it is more work, money, and hassle.
It would cost roughly the same amount to get to 500 rwhp via HC and FI. With the HC setup you would be talking high-quality parts and a fairly high state of tune, so that means a rough idle, etc. For FI you're just talking about a good kit on an otherwise totally stock engine.
Good headers are worth 15-20 rwhp on a mild engine, maybe 30 on a hotter enigne. They are not necessary, just traditional. The C5 has a particularly good factory exhaust system, so you don't gain as much as with many cars. Still, to hit 500 NA you're going to need them. FI, not so much. You pays your money and...
There will probably be guys saying that's way high. They didn't keep their receipts.
All just IMO.
Your posts are very informative and cover many bases.
