Heads Up Display - Is it Adjustable?
Old May 24, 2007 | 10:28 AM
coldbeer4dasoul's Avatar
coldbeer4dasoul
Default Heads Up Display - Is it Adjustable?
2001 C5 Coupe
My heads up display seems to have dropped a bit.
When driving sitting in my normal posture, the display is lower than it used to be. When looking at it, I only see the top half without sitting up very straight.
Is this adjustable??
Thanks in advance for any help.
CB4Soul
Old May 24, 2007 | 10:31 AM
cam99's Avatar
cam99
Yes it is Both height and illumination and Page ( Oil, Gas, etc)
Its on the left side of the dashboard.
Old May 24, 2007 | 10:33 AM
coldbeer4dasoul
thanks, I'll go check it out
Old May 24, 2007 | 10:34 AM
SilvaDragon's Avatar
SilvaDragon
Originally Posted by coldbeer4dasoul
2001 C5 Coupe
CB4Soul
Right below the dimmer control on the dash are the up and
down arrow keys for changing the HUD projection location on
the windshield.
But seriously - it's in the owner's manual.
Old May 24, 2007 | 10:36 AM
coldbeer4dasoul
Wow do I feel like a dumbass
Thanks for your help.
Old May 24, 2007 | 10:49 AM
SilvaDragon
No extra charge.
Old May 24, 2007 | 11:35 AM
rws.1's Avatar
rws.1
that's OK, welcome to the family, there are (or have been) a lot of dumb assess here... hopefully after a while on-board you will lose that status and start sharing your new found knowledge...
Save the Wave and share the Knowledge....
Old Jun 23, 2007 | 10:31 PM
z06Bigbird's Avatar
z06Bigbird
Should we agree with this guy????
Old Jun 24, 2007 | 12:18 AM
lawZ's Avatar
lawZ
now,where did I put that owner's manual?
Old Jul 9, 2007 | 04:48 PM
jmmy's Avatar
jmmy
Mine has dropped off bottom of dash and won't come up. I even tried that little adjusty thingy that makes it go up and down. Any other suggestions ?
Old Jul 9, 2007 | 05:10 PM
SilvaDragon
So, you can look in the window from the outside and see that
the projector is on? In other words, you know for sure that the
projector is working?
Old Jul 9, 2007 | 05:18 PM
BanditDude's Avatar
BanditDude
...and it's not fully dimmed.
Old Jul 9, 2007 | 10:14 PM
GUSTO14's Avatar
GUSTO14
I just installed a HUD system in my 2000 hardtop this past weekend. Thank you minytrker...
Once installed, I discovered that when adjusted fully up, I could see only about 3/4's of the display. However by raising the rear leg (point closest to the steering wheel) I could see the display perfectly. It only required raising the leg about a 1/4 inch, and the rear leg is in a slot so raising it this much was no problem. The difficulty is, if this is your only alternative to pulling the display up, you're gonna have to pull the dashboard... good luck...
GUSTO
Old Aug 1, 2007 | 06:23 PM
jmmy's Avatar
jmmy
Yes,
You can see the display, not even a little dimmed, it's just off the bottom like you ran it down on purpose. Just won't come up.
Old Aug 1, 2007 | 06:27 PM
jmmy's Avatar
jmmy
Yeah, pulling the dash was what I'd hoped to avoid. Any body got a set of directions or tips. Since I posted the HUD the oil sending unit died and the passenger window won't come up. I like working on all my cars but this is adding up a little fast.
Old Aug 2, 2007 | 09:15 AM
SilvaDragon
Josh has the goods here:
http://joshker99.home.comcast.net/hudinstall2.htm
Bummer, dude. Good luck with the repairs!
Old Aug 2, 2007 | 09:42 AM
LoneStarFRC's Avatar
LoneStarFRC
In your case it's possible you have either a switch failure (controlling the up/down) or a HUD projector drive motor failure.
Most likely however, I would suspect a connector being poorly seated as the problem. Requires IP removal only. I would check to make certain the connectors are fully seated on both ends of the 11 wire connector cable.
Good news: If the switch is bad you only need to remove the IP.
Bad news: If the HUD projector drive motor is bad, you'll be pulling the dash pad again and replacing ($$$) it.
HTH
To Heads Up Display - Is it Adjustable?
Old Aug 2, 2007 | 10:22 AM
Torqued84's Avatar
Torqued84
Ref the passenger window... Have you tried holding the window up button while slamming the passenger door hard? That has been an easy fix for a lot of us and would knock out 1 of your 3 problems.
Old Aug 19, 2007 | 06:23 PM
jmmy's Avatar
jmmy
Thanks for the tips guys. The door slamming thing didn't help but there were encouraging words in the connector suggestion.
This is first Vette and the part that worried me before I bought it was the headlight drive......Silly me.
Old Aug 19, 2007 | 08:42 PM
speedsk899's Avatar
speedsk899
There is an owners manual?
