St. Jude Donor '07-'08-'09-'10-'11-'12'-'13-'14-'15
Mounting points for racing harnesses?
I have a set of Corbeau retractable harnesses and need to get a better top mounting location. The high OEM seatbelt mounting point is at too much of an angle. Anyone know another location for mounting? Thanks
I don't know much about the retractable harness you mention, but what most do is by a kit which contains a harness bar that goes across behind the seats (anchors at the seatbelt shoulder location) that you then anchor the shoulder straps too.
There are many varieties, Hardbar is popular.
If you can give more detail about your harness, it will be easier to help.
If you need mounting points for the lower mounts, there are also kits for these. Brey Krauss and Hardbar are the most popular (I use BK).
