a/c broke help
Old May 25, 2007 | 04:57 PM
Tikiman12's Avatar
Tikiman12
Default a/c broke help
so my passenger side A/C is constantly blowing the heater. face and legs both always blow heater only. whats wrong?
Old May 25, 2007 | 05:34 PM
corvettedoug's Avatar
corvettedoug
So both sides only blow hot air? If so I would check the freon and the a/c compressor (clutch engages on and off). If one side will blow hot and the other cold, then you might want to try the actuator relearn process for the vents. There are several posts for how to do this.
