Question for C4C5 Tech
Old Oct 23, 2001 | 12:25 PM
VNVETT's Avatar
VNVETT
Default Question for C4C5 Tech
On my 01 Zo6 when I pull the key out only the passenger side door unlocks automatically. When I get in the car and take off both doors lock as they are supposed to but when I stop and remove the key only one sid(passenger unlocks, any suggestion on what to check out before I take it to the dealer> Thanks VNVETT
Old Oct 23, 2001 | 07:44 PM
ersatz928's Avatar
ersatz928
Default Re: Question for C4C5 Tech (VNVETT)
Could be the door module (controls the power windows, locks, and mirror, each door has it's own module) : doesn't recognize commands on the serial data bus. Check for communication trouble codes.
Old Oct 23, 2001 | 08:47 PM
VNVETT's Avatar
VNVETT
Default Re: Question for C4C5 Tech (ersatz928)
Thanks I'll try it tomorrow, everything else works just fine. VNVETT
Old Oct 24, 2001 | 01:24 AM
Richin Chicago's Avatar
Richin Chicago
That's one of the options.. Hit the option button and go through the list. You can set it so both doors unlock.
Old Oct 24, 2001 | 02:09 AM
ace's Avatar
ace
Default Re: Question for C4C5 Tech (Richin Chicago)
Exactly. Go to options, there is a setting for 'auto unlock driver' or you can choose 'auto unlock both' , or 'auto unlock off'. Auto lock must be set to 'on'. Good luck!! :p:
To Question for C4C5 Tech
