Need AC Help
Old May 29, 2007 | 10:43 AM
wclark@nj.com's Avatar
wclark@nj.com
Default Need AC Help
Here's my story:
The AC light wouldn't stay on - blinks then off. So, I got a can of sealer (had a can of 134). I put in the sealer then the 135 till the guage was in the 25-45 range. Now the AC light stays on and you can hear the compressor come on (and off if you hit the AC button again) but no cold air?
Anything else I can do before finding a repair shop?
Old May 29, 2007 | 11:02 AM
ronwc's Avatar
ronwc
Try pulling the 27 fuse to reset AC, also you may need to clear codes on DIC -
Old May 29, 2007 | 01:59 PM
nickolbag's Avatar
nickolbag
throwing any codes?
Old May 29, 2007 | 02:08 PM
wclark@nj.com
no codes
pulled fuse - didn't fix the problem
Old May 29, 2007 | 04:10 PM
kevin40zx's Avatar
kevin40zx
I had the same problem. Sometimes the light would blink and then turn off. I did nothing and the more I used the ac the problem ceased to happen. Weird?
Old May 29, 2007 | 09:58 PM
GeorgieMporgie's Avatar
GeorgieMporgie
I've got the same issue? A/C lights blinking and A/C not working.
Old May 29, 2007 | 10:25 PM
VetteTech81's Avatar
VetteTech81
Let the shop know you put sealer in! It is the worst thing for AC Recovery machines.. Equipment is expensive so I am sure they will appreciate it..
-=Rick
Old May 30, 2007 | 09:18 AM
wclark@nj.com
Now I just have to find a "good" local shop to go to...
Old May 30, 2007 | 10:50 AM
00Corvette's Avatar
00Corvette
Yeah I posted earlier but I'm actually having the same problem right now also...
Donnie
Old May 30, 2007 | 10:57 AM
sgreen4067's Avatar
sgreen4067
mine did that, put 2 new cans of 134a and now the unit blows ice cold and works fine.
Old Jun 4, 2007 | 04:26 PM
wclark@nj.com
I took the car in to a shop .... compressor shot ..
They want $1500 to replace the compressor, dryer & orifice tube.
I just ordered a new compressor, dryer & orifice tube for $249.
Any tips for replacement?
Old Jun 4, 2007 | 09:51 PM
kevin40zx's Avatar
kevin40zx
Fuse #27 under the hood says "spare" ?
Old Jun 5, 2007 | 04:07 AM
ronwc's Avatar
ronwc
It's not under the hood, it's in the passenger side footwell -
To Need AC Help
