voltage problems
Old May 29, 2007 | 03:53 PM
bumble bee's Avatar
bumble bee
2nd Gear
Default voltage problems
I have a 2001 6 speed that when you turn on ignition all dash lights flicker and it reads low voltage I checked the battery and it was showing 12.7 on the volt meter it done this a few times in the past but now it is at least ever other time i try to start it there has been a few times it died going down the road but then started right up help please cant afford to have dealership experiment
Old May 29, 2007 | 04:30 PM
SilvaDragon's Avatar
SilvaDragon
Follow the leads from the battery and make sure they are firmly
attached at both ends, particularly the lead to the starter.
If that checks out, carefully read the sticky topic
"Important Electrical Information" in this section.
Seriously.
Itallian33's Avatar
Itallian33
I just went through a problem with my electrical system. (it was the positive stud on my starter)
Is the car throwing any codes??
Here is a good link:
http://www.corvettedoctor.com/Code_Main.html
Best advice i can give you is to check every cable (battery to starter, starter to alternator, battery to frame, battery to block, etc....) and look for a loose connection or a corroded connector. Always a good starting point. It is important to give the cables a little tug to make sure that they are firmly attached to the connector.
There is a ground pack in the rocker pannel by your left foot, in front of the dead peddal and underneath your hood latch where the grounds for the dash are located. Another one on the other rocker pannel where the grounds for the PCM and Interior fuse pannel is located. the Electrical information sticky at the top of this forum also has a lot of good information.
To voltage problems
