service traction control help
Old May 30, 2007 | 09:16 AM
bumble bee's Avatar
bumble bee
2nd Gear
Default service traction control help
I Have Cleaned Both Grounds Behind Headlights Checked Battery Grounds And Ground Going To Starter All Looked Good When I Turn Switch On Dash Lights And Gauges Go Crazy And Usually Displays Low Voltage Service Traction Control Reduced Engine Power If I Turn On Switch Then Pess Traction Control Off Everything Goes To Normal Then After I Start It I Can Cut Traction Back On I Have An Appointment Tommorow At Dealership If I Cant Figure Out Pretty Quick
