Intermittent shift selector (auto) problem
Old May 30, 2007 | 08:51 PM
Dually Driver's Avatar
Dually Driver
Default Intermittent shift selector (auto) problem
When I press down on the button on top of the shifter handle it may or may not allow me to shift. Is there a relay or something that is not being energized. Any help would be appreciated.
Mike
Old May 30, 2007 | 10:24 PM
C5starman's Avatar
C5starman
CI 7-8 Veteran
Don't think so. I put an adapter on my shifter so it will accept different shift *****. If I remember correctly pushing the button is a mechanical connection, not a relay.
Of course my wife has noted that I am wrong alot.
Old May 31, 2007 | 10:23 AM
Fast one's Avatar
Fast one
There is a solenoid in the shifter to prevent shifting out of park unless the brake pedal is pushed. Check the brake switch operation.
Old May 31, 2007 | 11:19 PM
rockittboy's Avatar
rockittboy
mine does the same...seems to do it more if it sits all night out in the cold. on a side note, are there any aftermarket auto shifter setups?
Old Jun 1, 2007 | 04:01 PM
aleadfoot's Avatar
aleadfoot
Yes there is an adapter that will allow you to use any ****
To Intermittent shift selector (auto) problem
