Lowering Problems
Old May 30, 2007 | 11:03 PM
shihiran's Avatar
shihiran
Default Lowering Problems
Hey All, I Need Help. I Was Lowering My 98 Vet On The Stock Bolts. The Rear Was No Problem, The Two Front Bolts I Could Not Turn At All I Think There Lock.
Old May 30, 2007 | 11:15 PM
roushraven's Avatar
roushraven
Coolest Guy Evar!
Did you relieve tension on the front leaf spring?
Old May 30, 2007 | 11:18 PM
shihiran's Avatar
shihiran
Yes I Did Jack Up The Leaf Spring
Old May 31, 2007 | 02:47 AM
NITRO UK's Avatar
NITRO UK
hi
try w d 40, penertrating oil.
Old May 31, 2007 | 09:27 AM
C5 ChemE's Avatar
C5 ChemE
I had the same issue with my fronts. Tried EVERY trick the forum members suggested, and none worked. Finally stripped the heads off the bolts and just gave up.
My last resort, which I haven't tried yet, is taking the whole spring out, sticking the bolt in a vice, and turning the whole spring.
Mine's hopeless, but hopefully you get yours straightened out.
Old May 31, 2007 | 09:43 AM
roushraven's Avatar
roushraven
Coolest Guy Evar!
Before going to that extreme you could relieve just enough tension to raise the spring side you are trying to adjust. Then use channel lock pliers on the base of the isolator and turn it. If that doesn't work, then yes remove the spring completely from the car; adjust and replace.
-RR
Old May 31, 2007 | 10:17 AM
Fast one's Avatar
Fast one
There is a smooth steel insert molded into the plastic spring that the bolt screws into. As a last resort it is possible to tap the insert down with a deep well socket or tube over the bolt so that the insert separates from the spring. You can see part of the insert top at the bottom of the bolt. The removed insert/ bolt can be put in a vice and heated so that the bolt will unscrew. The insert threads should be cleaned with a tap then the insert is epoxied back into the spring, just degrease the areas to be glued. Since the hole that the insert fits is not all the way through the spring the strength is not compromised. It might be necessary to separate the lower ball joint from the steering knuckle for more room to work but do not use a pickle fork since it will ruin the ball joint seal. Most of these bolts respond to penetrating oil but some don't. I protected the spring with aluminum sheet/ aluminum foil and used heat on the bolt along with Kroil and the result was the insert rotating with the bolt, that's when it was tapped down and out with a hammer. I had to do this three years ago on my '98 and it worked well. I don't know if the inserts were redesigned on later years.
Old May 31, 2007 | 11:30 PM
shihiran's Avatar
shihiran
THAT SOUND LIKE A LOT OF WORK.WHY THE SHOP I TOOK IT TO COULDN'T LOWER THE FRONT EITHER. THEY SAID IT WILL BE $200 IF THEY DO LOWER IT. WHEN MY FRIEND JUST GOT HIS 99 LOWER RIGHT BEFORE ME FOR $75.
To Lowering Problems
