Need help with AIT sensor
Old May 31, 2007 | 09:08 AM
Monte04ss's Avatar
Monte04ss
Default Need help with AIT sensor
Hello gang,
need some help please, I installed my new halltech last night and damaged the little cage or guard around the air intake temp sensor. The sensor part is 100% fine no bends or issues, just the little plastic cage part that protect the sensor in the air bridge.
I installed it anyway and took her for a rip, no codes no idling problems. Do any of you see an issue with leaving it like that >? or does that little plastic cage slow down the air for a proper reading ?
I really don't want to spend $80 if I don't need to replace it.
thanks in advance
Old May 31, 2007 | 09:42 AM
mrm1149's Avatar
mrm1149
St. Jude Donor '06-'07-'08-'09-'10-'11-'12-'13
You're looking fine with no codes......sensor must be working as designed
Old May 31, 2007 | 06:26 PM
NocarbutaVetteforme's Avatar
NocarbutaVetteforme
I would think you are ok since the little cage is probably there more for sensor protection than anything else. If you ever want to test your sensor you can use a dvm and then take a measurement across the leads using the resistance function. Then heat up the element with a hair dryer and then check the readings. If you see a change then you know it is reading the temperature change. As stated earlier, the cage is more for protecting the sensor element.
To Need help with AIT sensor
