If i use wheels on my C5 without TPS will I show a DIC all the time or can I turn TPS off or disable code? Thanks.
Your profile says you have a 2001 ... so the TPMS can be turned OFF with a Tech2 device. If you don't turn it off ... you will get a SERVICE TPMS message everytime you start the car (well, shortly after) ..
Why would you want to eliminate the system ??? A number of Z06 owners have added it to their cars because of the added safety (and less possible tire damage) that it provides.
Didn't want to eliminate it(them)but Im putting on 2002 ZO6 wheels, can i use my existing sensors?
Thanks! thats what I wanted to hear, now who do i trust to do the tire swap since I'm gonna keep my tires and sensors. do The tp sensors need to be reprogrammed by me,dealer,installer or? I miss my 64! It was so simle!
Any "good" tire shop should be able to mount the tires and sensors.
NOTE: The sensors are mounted by a nut ... tighten to 35 lb/inches (that's INCHES .. not feet) DO NOT OVERTIGHTEN as that can/will destroy the sensor.
