Rear-View-Mirror Will not Hold Position
Old Jun 1, 2007 | 09:37 PM
98Artic's Avatar
98Artic
Default Rear-View-Mirror Will not Hold Position
My interior Rear-view-mirror loses its position when the car hits bumps. Has anyone experienced the same problem? Is there a way to tighten it? It seems to be a ball-in-socket type joint with no adjustments. Thanks in advance for any answers.
Old Jun 1, 2007 | 10:12 PM
Ralphyboy's Avatar
Ralphyboy
St. Jude Donor '08-'09
I had the same problem with my 93. It drove me nuts. I never did fix it. Now I have an 03 with no problem. You might try taking some vice grips, and squeezing the part that holds the adjustment ball. If it bends a little, it might work.
Old Jun 1, 2007 | 10:37 PM
Bill Dearborn's Avatar
Bill Dearborn
I picked up a used one for $20. Try one of the forum vendors who sells used parts.
Bill
Old Jun 2, 2007 | 04:09 AM
jdmvette's Avatar
jdmvette
Night Owl for life
i've got my old one in the garage if you need a new one. is yours the non e/c version?
Old Jun 2, 2007 | 08:03 AM
98Artic's Avatar
98Artic
The vice-grip thing did occur to me. Maybe I will give that a try, and if that doesn't work, it look like that I will have to spring for either a new one or a used one. Thanks. Mine is simply the one that comes standard on a 98 C5. Are not they all the same? I do not know what you mean by e/c version.
Old Jun 2, 2007 | 11:53 AM
BlackZ06's Avatar
BlackZ06
Some mirrors (optional equipment) have a light sensor in them. At night the mirror "automagiccally" dims when bright lights are behind you. It uses an "electrochromic" (hence the e/c) coating on the mirror to do this. You'll have a small button on the mirror to turn the feature on/off.
Old Jun 2, 2007 | 12:03 PM
screw991le's Avatar
screw991le
From: Redsox, Pats, Celts & Bruins !!! Redsox Nation !!!
St. Jude Donor '06-'07-'08-'09-'10-'11-'12
If you do not have the auto dimming mirror, now is the time to add one. The link is just a guide. The mirror and harness can be purchased for much less.
http://www.c5forum.com/diy/electro_mirror.php
Old Jun 3, 2007 | 01:17 AM
JPCCDD's Avatar
JPCCDD
I had this same problem. Turn that black 2" tube on the back about 90 degrees. problem solved.
Old Jun 3, 2007 | 12:59 PM
'VETTE PHASE's Avatar
'VETTE PHASE
Cruise-In VIII Veteran
Chevrolet didn't offer the elecrochromic mirrors in vettes until '01.
Old Jun 4, 2007 | 01:00 AM
white90conv's Avatar
white90conv
I installed the e/c mirror on my car and am very happy with it at night. However, during the day when the sun is directly behind you, the manual mirror could be dimmed but the e/c mirror cannot. I would still go with the e/c mirror but this is something to consider.
Old Jun 4, 2007 | 08:26 AM
Billdog350's Avatar
Billdog350
I have the same problem with my rearview moving down slowly...I'll try the "rotate tube 90 deg" suggestion first...it seems like it will work since it doesn't move side to side at all...just up and down.
Old Jun 4, 2007 | 05:45 PM
98Artic's Avatar
98Artic
I did the 90 degree rotation and took it out to some bumpy roads. Seems to have worked. It still does not feel real tight, like I would prefer, but maybe this will work for a while. Thanks for the suggestion JPCCDD. If it begins to slip again, I was thinking about dropping a drop of superglue in the joint. (I don't think that that would freeze it entirely?)
To Rear-View-Mirror Will not Hold Position
