B0338 code ??
Old Jun 2, 2007 | 10:49 AM
01rc51's Avatar
01rc51
Default B0338 code ??
I took the dash apart and plugged the temp sensor back in and its still putting the code back up after clearing it out, and for a sec after I clear it out the heat comes back on, then it will go back to blowing not very cold air. Does anyone have any ideas and, or the part number for the inside temp sensor.
David
Old Jun 2, 2007 | 11:39 AM
BlackZ06's Avatar
BlackZ06
The Inside temp sensor is part # 16267411
HTH
Old Jun 2, 2007 | 11:44 AM
BlackZ06's Avatar
BlackZ06
If the temp sensor is bad ... the A/C system uses a "default" temperature so the A/C system still "runs".
B0338 is after checking wiring, according to service manual, fixed by replacing the sensor.
Old Jun 2, 2007 | 01:42 PM
01rc51's Avatar
01rc51
thanks for the info
To B0338 code ??
