Help Error codes after header install
Old Jun 2, 2007 | 07:40 PM
Lan.Jet's Avatar
Lan.Jet
Default Help Error codes after header install
I just finished installing LG header and they recommended using the rear sensors in the front and not reconnecting the rear sensors. I now get a p0160 & p0140 no activity in sensor. Because they are not connected. Any help on how to get around this would be appreciated. Thanks
Old Jun 2, 2007 | 08:23 PM
dpd's Avatar
dpd
fix choices are:get another set of rear o2's
find simms
tune them out with edit/efilive/hptuners
Old Jun 2, 2007 | 11:29 PM
SteveDoten's Avatar
SteveDoten
Cruise-In VII Veteran
you used the short harness that adapts the rear 02 conn to the front?
Old Jun 3, 2007 | 09:32 AM
Lan.Jet's Avatar
Lan.Jet
Yes I used the short adapters to connect the rear sensors to the front harness. The rear harness is now empty. This is how LG said to connect them. I have no problem buying a second set of rear sensors and installing them also but LG said it would not run good.
To Help Error codes after header install
