Trying to hit 5th gear but get REVERSE
Old Jun 3, 2007 | 10:42 AM
FallenWhun's Avatar
FallenWhun
Default Trying to hit 5th gear but get REVERSE
its a 99 hardtop. isn't reverse supposed to be locked out when driving on the freeways? There arent any pcm codes showing up... How much would you estimate to fix this kind of problem?
Old Jun 3, 2007 | 11:47 AM
ArKay99's Avatar
ArKay99
There is a reverse lockout solenoid mounted on the transmission to keep you from accidentally going into reverse when going from 4th to 5th. If that isn't happening my first guesses would be the solenoid is dead, the connector is flaky, the wiring is damaged, or the ground for it is corroded. The fix cost would be dependent on the tech you brought it to. I would find a tuner on this forum in your area. It shouldn't be a big deal to fix, but you are right on the money in your concern for this problem and the need to get it fixed. If you get it into reverse and let the clutch out at highway speed there will a lot of parts on the road.
Old Jun 3, 2007 | 05:41 PM
Jim2003's Avatar
Jim2003
My solenoid did the same thing on my 03 mn6. The dealer fixed it under warranty. The reverse lockout solenoid it located on top of the tranny. It is a real pain in the butt ot work on. The tech at my dealer had a big socket that fit over it. He was able to slowly back it out and get the new one in with no troubles.
Old Jun 3, 2007 | 11:32 PM
GreyGT-C's Avatar
GreyGT-C
damn... it takes both hands to get mine into reverse at a dead stop. and sometimes i still put it in 5th by accident.
Old Jun 4, 2007 | 12:09 AM
FallenWhun's Avatar
FallenWhun
just curious... how much would it cost to repair a problem like this?
Old Jun 4, 2007 | 09:40 AM
FallenWhun's Avatar
FallenWhun
ttt
Old Jun 4, 2007 | 10:43 AM
MadMaxZ06's Avatar
MadMaxZ06
I had the same problem with my M12 on my '03 Z06. Reverse lockout solenoid. It's been perfect ever since. I believe the solenoid is cheap. Check with Gene Cully.
- Max
Old Jun 4, 2007 | 10:59 AM
MR496's Avatar
MR496
Default Diagnosis????
First off, does everything else work in the car? Speedometer, Cruise control, HUD if equipped? I will assume they do by your earlier response. There are a few things that tell the reverse lockout to engage above 3 MPH. I think that since the car isn't picking up any codes that it may be what was earlier discussed. Just don't get headstrong and go in and spend a bunch of money on changing this and that to find out that it was something else all the time. I speak from experience but from the mechanical end not the owners.
Mike
To Trying to hit 5th gear but get REVERSE
