Headlights What did I do Wrong
Old Jun 3, 2007 | 10:55 AM
corvetteman3's Avatar
corvetteman3
Default Headlights What did I do Wrong
Replaced the gear (Drivers side) Put assembly back in car. Now when I turn the lights on they go down. When OFF they go UP!@@@@@#@#$@
Help!!!!
Old Jun 3, 2007 | 10:58 AM
gtragitt's Avatar
gtragitt
Cruise-In II Veteran
Cruise-In III Veteran
St. Jude Contributor
Your linkage is not connected correctly to the motor. You will need to have the pivot point in the alternate position.
Greg
Old Jun 3, 2007 | 11:02 AM
corvetteman3
Will give it a try. Thanks
Old Jun 3, 2007 | 09:46 PM
gtragitt's Avatar
gtragitt
I hope you got it working correctly. If you didn't, PM me with your phone number and I will call you.
Greg
Old Jun 4, 2007 | 06:47 PM
corvetteman3
That did not fix the problem. will pm you.
Old Jun 4, 2007 | 08:36 PM
corvetteman3
Took the gear out rotated 180 degrees. put back together. Same results.
To Headlights What did I do Wrong
