Fuel Door Problem
Old Jun 3, 2007 | 11:44 AM
electra's Avatar
electra
Default Fuel Door Problem
I have read all the posts about this; tested the fuse and replaced the switch (part# 10276017) and the remote fuel door opener still does not function. There is no sound associated with actuation so I think it is electrical as opposed to mechanical. Does anyone know what the voltage should be to the switch? Any personal experience? I am weary of opening the trunk every time I need fuel. Thanks in advance for any help!
Old Jun 3, 2007 | 02:12 PM
65GGvert's Avatar
65GGvert
12volts to the switch. Puts 12 volts on the solenoid at the fuel door. It has to have a ground for the solenoid too. I'm betting you don't have 12volts at the switch, or the solenoid is stuck or open.
Old Jun 4, 2007 | 10:50 AM
electra's Avatar
electra
Thanks for the info 65G; I will ohm the volts and see whats up..
Old Jun 4, 2007 | 11:16 AM
mrm1149's Avatar
mrm1149
St. Jude Donor '06-'07-'08-'09-'10-'11-'12-'13
I have several fuel door switches that mount in the drivers console if you need ............
To Fuel Door Problem
