problem with my vette
Old Jun 3, 2007 | 12:59 PM
hosers's Avatar
hosers
1st Gear
Default problem with my vette
I have a 2000 vette I have two problems 1 when you put it in gear the rpm's go up and I have to keep on the brakes or it will take off, not shure what to check to fix the problem .2 some times when you start it up it back fires real loud, but it dosen't due it all the time,if I cycle the key it will start, not shure if I have bad fuel injectors or in the computer, I had the cam sensor replaced,but my check eng light is on it come back to the cam sensor I need help
