ACK!! Code P1416...
Old Oct 24, 2001 | 05:34 PM
BatMobile's Avatar
BatMobile
Tropical Moderator
Cruise-In 1-5 Veteran
St. Jude Donor '03-'04-'10-'11
Default ACK!! Code P1416...
Right side AIR Pump check valve!!
DANG IT!
That blows CHUNKS!
Oh well. Looks like a bit more hands on work for yours truly!
:rolleyes:
Neill
Old Oct 24, 2001 | 05:56 PM
B. Stewart's Avatar
B. Stewart
Default Re: ACK!! Code P1416... (BatMobile)
Did you recently put on a set of headers? I started setting codes, both P1415 and P1416 after I installed a set of B&B shorties. I replaced both check valves and the AIR pump and continued to get the same codes. Now I only get one every month or so. :mad
Old Oct 24, 2001 | 08:26 PM
MattG's Avatar
MattG
Cruise-In I, II, III, IV & V Veteran
CI-I & II Auto-X Champ
Default Re: ACK!! Code P1416... (B. Stewart)
Is this the opposite side to what you replaced already?
Old Oct 25, 2001 | 08:55 AM
BatMobile's Avatar
BatMobile
Tropical Moderator
Default Re: ACK!! Code P1416... (MattG)
Yeap...had P1415, and replaced the left side check valve, which was a piece of cake...maybe 5-10 minute job.
The right side you have to remove the intake manifold...
grrrrrrr
Neill
PS...and yes, a recently installed set of TTS headers.
To ACK!! Code P1416...
