Does a faulty Fuel sender always throw a code?
Old Jun 4, 2007 | 11:02 PM
Vettman 1's Avatar
Vettman 1
Default Does a faulty Fuel sender always throw a code?
Title says it all. My fuel gauge is (very) intermittant. A couple times it stuck on "full" for a few days, then dropped to 1/2. Once it stuck on "E" then fixed itself. Most of the time it function OK The dealer will not replace the sending units (under warranty) unless there's a code stored (which there is not.)
Old Jun 5, 2007 | 08:42 AM
Doug@MorosoPerformance's Avatar
0Doug@MorosoPerformance
Former Vendor
A faulty fuel sender usually will not throw a code. Do a search on faulty fuel senders and you will find many post on this very common problem.
Old Jun 5, 2007 | 12:19 PM
PUREFUN's Avatar
PUREFUN
St. Jude Donor '07-'08
Occasionally mine acts up also without sending any codes. Probably heard this before but add a bottle of Techron in the next tankfull. This time i added one the last two tankfulls. So far each time (4) in the last two years have cured the problem.
Old Jun 5, 2007 | 06:27 PM
bcseitz's Avatar
bcseitz
Mine never threw a code. Just gives me the "SUPRISE!! YOUR OUT OF FUEL!!" warning when I'm really not! And I always use Chevron Supreme too.
Old Jun 5, 2007 | 06:29 PM
bcseitz's Avatar
bcseitz
Mine never threw a code. Just gives me the "SUPRISE!! YOUR OUT OF FUEL" warning when I'm really not! And I always use Chevron Supreme too.
To Does a faulty Fuel sender always throw a code?
