Reduced engine power, Shocks Inoperable, Service Traction Control????
Old Jun 5, 2007 | 09:09 AM
KalelC5's Avatar
KalelC5
Default Reduced engine power, Shocks Inoperable, Service Traction Control????
For the last 2 days, EVERY time I start my vette, I get the Check Tire Pressure, reduced Engine power, Maximum speed 80mph, Service Tracion Control, etc.... Anyone have any clue what is wrong?? Im suspecting I might need a new BCM?! any help would be appreciated thanx
Old Jun 5, 2007 | 09:32 AM
BlackZ06's Avatar
BlackZ06
You need to check for DTCs and list them here. If you don't know how to do that see:
https://www.corvetteforum.com/techti...D=26&TopicID=1
Old Jun 5, 2007 | 01:06 PM
KalelC5's Avatar
KalelC5
I cant pull any codes.....all it says it "No Comm." which I'm assuming is No Communication with the computer??!
Old Jun 5, 2007 | 02:10 PM
KalelC5's Avatar
KalelC5
i tried disconnecting the battery, and that didnt work, anyone???!!!!
Old Jun 5, 2007 | 02:27 PM
dougbfresh's Avatar
dougbfresh
Did you check the tire pressure??
Old Jun 5, 2007 | 05:14 PM
BATM4N's Avatar
BATM4N
My stem had a leak and went down to 17 psi and you could barely tell it was flat
Old Jun 5, 2007 | 05:34 PM
petercln's Avatar
petercln
check your start conectors they are located under the passanger side kick panel. See the sticky at the top of the page.
Old Jun 5, 2007 | 06:37 PM
Van5150's Avatar
Van5150
When this happens., Is the dashboard now lit up those symbols like service engine now, and goes away after you turn off the engine and restart?
Old Jun 5, 2007 | 08:07 PM
KalelC5's Avatar
KalelC5
Yes all the symbols are lit after the car is started, and every idiot message flashes on the DIC, and it goes away after i restart it then comes on again.....
Old Jun 5, 2007 | 08:52 PM
Bob Chapman's Avatar
Bob Chapman
Ask Bill Curlee - he's really good on these issues.
Old Jun 5, 2007 | 08:56 PM
KalelC5's Avatar
KalelC5
ok will do thank you!
Old Jun 5, 2007 | 09:59 PM
Van5150's Avatar
Van5150
The reason I asked is because I just experienced this 3 daysago., freaked me out.
I think this is our answer.
http://forums.corvetteforum.com/showthread.php?t=896875
Old Jun 5, 2007 | 10:06 PM
$$$frumnuttin''s Avatar
$$$frumnuttin'
From: Should this thoughtful, valuable contribution meet with no acknowledgement or 'thanks' this post----
sounds like you have F45 suspension...I got all those codes when one of my shocks went bad.
Old Jun 6, 2007 | 05:58 PM
KalelC5's Avatar
KalelC5
Yes I have F45 You had all the symptons my vette had cause of one of the shocks went bad??? How could I check?? Thanx
Old Jun 7, 2007 | 04:06 PM
SinghZvette's Avatar
SinghZvette
Default Welcome to ...
I have the EXACT SAME PROBLEM and have the F45 suspension. Have been dealing with it for a while since the messages appear only once a month. Very first "money-saving" diagnositics:
1. clean the under hood ground contacts (
http://forums.corvetteforum.com/showthread.php?t=896875 awesome info supported with pics ..)
2. check the accordion style pipes near the door openings, they contain some wires and contacts that tend to go loose.
I did the 2 above and the problem still persists. Will be visiting the stealership soon since it means the shocks are bad. Anyone have any idea how much it will cost $$? Do I have to replace all shocks or only the one that is bad?
Old Jun 7, 2007 | 08:55 PM
BlackZ06's Avatar
BlackZ06
Have you tried this again ?? If so, and you're getting the NO COMM message, that would indicate the IPC has communication problems ... but then I don't know how you're getting gauge readings if the IPC is in a NO COMM condition. Or, are you getting output from some computers, but one is coming back NO COMM ??
Try for codes again ... something doesn't sound right.
To Reduced engine power, Shocks Inoperable, Service Traction Control????
