How to? PS cooler
Old Jun 6, 2007 | 10:10 PM
Snidley's Avatar
Snidley
Default How to? PS cooler
Any one have information on the installation of a power steering oil cooler? Mine overheats on the track and sprays oil all over the place.
Old Jun 7, 2007 | 10:34 AM
Bob K's Avatar
Bob K
St. Jude Donor '11-'25
Default PS Cooler
Steve,
The factory PS cooler's have the following part numbers:
26088760 (98-00)
26088744 (01-02)
I hope this helps.
Bob K.
Old Jun 7, 2007 | 11:02 AM
AzMotorhead's Avatar
AzMotorhead
Limping across the line
After just doing the rack on a 98 The "cooler" isnt anything more than a long section of hardline that runs from the rack back to the resevoir(sp?).
An aftermarket cooler would be easy to add. Locate the 3/8 rubber line that ports into the P/S resevoir coming up from the hardline attached to the rack. That is the return line and its low pressure,so put the aftermarket cooler in that line
Old Jun 7, 2007 | 11:18 AM
Bill Dearborn's Avatar
Bill Dearborn
The Z51 and Z06 coolers are finned coolers not just a piece of pipe.
Bill
Old Jun 7, 2007 | 11:35 AM
AzMotorhead
Noted the car I worked on had F45 suspension
Old Jun 7, 2007 | 12:28 PM
Bob K's Avatar
Bob K
Default Here's a link to the pdf file
This link has diagrams and part numbers for PS cooler.
http://forums.corvetteforum.com/show...artsManual.pdf
If you want picture, just ask. I can't post them, but I will mail them to you.
The car is getting an oil change this afternoon (I put my first 100 miles on the new 402) so I can get a good picture with it in the air.
Bob K.
Old Jun 8, 2007 | 10:27 PM
Snidley's Avatar
Snidley
Thanks for all the info. Its going into the dealer (under extended warrenty) to check it out for the second time. If I can manage it, I'll get the Z06 oil cooler line put in.
Old Jun 8, 2007 | 11:31 PM
Bill Dearborn
Ken Fichtner used to advertise the coolers several years ago. In 2000 I purchased one from him to install on my 97. It is a simple job and I was able to do it just using a jack and a couple of jackstands to get the front of the car high enough.
Bill
To How to? PS cooler
