L92 valvecovers
Old Jun 7, 2007 | 11:34 AM
dhirocz's Avatar
dhirocz
Default L92 valvecovers
What valvecovers are you guys with L92's running? Weren't LS1's up to '99 perimeter bolt and later models were centerbolt? What do the L92's take?
Help me out. I'm completely clueless here, lol. I'm guessing also that us early LS1 guys using the L92's would need a different set of coil brackets to accomodate...
Old Jun 7, 2007 | 11:53 AM
99C5JA1's Avatar
99C5JA1
A quick look in the L92 section on LS1Tech indicates they use the centerbolt configuration found on '99+ motors.
http://www.ls1tech.com/forums/showth...&page=11&pp=20
Post #220 shows the heads with the centerbolt holes clearly visible.
Old Jun 7, 2007 | 12:17 PM
Bob K's Avatar
Bob K
St. Jude Donor '11-'25
Default L92 Heads / '00 LS1 Valve Covers & Brackets
I'm using the valve covers and coil brackets from my '00 LS1 on my L92 heads.
I had to modify (grind) the oil baffel in the right valve cover to clear the offset rockers. No big deal.
Bob K.
Old Jun 7, 2007 | 12:55 PM
dhirocz's Avatar
dhirocz
Ok so I need to use '99+ centerbolt valvecovers. I guess the coil brackets are also different?
Since I forgot to ask let me ask you this... what are you guys with LS1 based motors (not LS2's) doing for valley covers? Stock LS1?
Old Jun 7, 2007 | 01:58 PM
99C5JA1's Avatar
99C5JA1
You would need '99+ valve covers. Looking at an exploded view of a 97-98 head it looks like you would need the appropriate coil bracket as well. P/N 12563288 and is $8-10 a side.
Old Jun 7, 2007 | 07:49 PM
7LitreC5's Avatar
7LitreC5
Katech.
Old Jun 7, 2007 | 11:38 PM
dhirocz's Avatar
dhirocz
My guess is those wont fit under stock fuel rail covers?
Those look pretty nice though. Especially the valve covers. Where'd you get those, same place?
Old Jun 8, 2007 | 07:46 AM
7LitreC5's Avatar
7LitreC5
My fuel rail covers wouldn't have fit with the L76 intake so that was my excuse to get nice valve covers. The valve covers and coil relocation brackets are all from Katech. They can be ordered direct from them.
Old Jun 8, 2007 | 09:45 AM
WKMCD's Avatar
WKMCD
Here's mine with L92/L76 setup.
I have my stock center bolt covers if you need a set.
To L92 valvecovers
