Tiling/Painting Garage Floors
Ceramic tile would be too pricy I think, but correct me if I'm wrong.
Vinyl tile seems more reasonable - maybe a commercial grade tile. Seems I can't find any pure white tiles though.
So, please post pictures of your garages and garage floors and please be as specific as possible about manufacturers, where you bought it, maybe even part numbers. I have gone to Home Depot and they said they don't sell white commerical grade vinyl tiles. I recall a member here saying he did buy the stuff for his floor from HD.
My garage is about 22' X 22'. It is starting to get cold here in New Jersey, so that might affect what I can do now also. I purchased Rustoleum Epoxy Shield, light gray, but I have not yet applied it as it is not what I really want.
Motormat is too expensive so I ruled that out already.
Your assistance would be greatly appreciated.
i remember reading about a heavy duty grade tile that is used in supermarkets.
It turned out very well. It has a high gloss shine (a bit slippery when wet), seals it, looks great and is easy too clean. I highly recommend it.
The paint is $55/gallon (used 3 gals.) plus the acid, about $200 total. A great investment.
If you REALLY want to do the job right, got to http://www.ucoatit.com I just got done doing my garage floor (20x20), and it's the real deal. It's an unusual, thin, runny two-part WATER BASED epoxy, so it has no affinity to tires once it has cured. Price is $250 for a kit that contains everything (rollers, brushes, stirrers, and a big bucket to mix it all in) except muriatic acid (1 gallon, $5 bucks, but not at Home Depot. HD only carries phosporic acid, which is not as "nasty". Try a hardware store or a pool supply) Anyway, I strongly endorse this product. It's the same stuff used in dealerships and hangars, but packaged for us homeowner guys.
First coat looks awful, as it literally soaks into the concrete. Second coat is killer!
Several colors are available, and this website shows several fancy painted floors....logos and such. Black and white checkerboard would be doable, but it's a masking nightmare.
[Modified by tracy, 2:20 PM 10/25/2001]
I'm telling ya.......www.ucoatit.com is the ****!!!!
[Modified by tracy, 4:44 PM 10/25/2001]
I washed the floor three times with simple green and the ucoat it cleaner and solvent, followed up with a muriatic acid wash.
I applied the first coat to a TOO WET floor. It should have been just damp, so I needed a third coat( third gallon) to cover it. I have had some tire patch lifting, but not bad. I don't know if it was the too wet first coat, or the 40 years of grease. I suggested to ucoat it that they sell smaller batches, ie quarts to patch the bad spots , but I got no reply. When I needed the third gallon in a big hurry, I called them and had them air freight out a gallon. The sales person even asked me for a lot number to insure a color match, and got it out after 5:00 pm his time, so I could have it the next day. Great service.
I used the anti-slip material to insure I wouldn't fall on my rear when the floor was wet, and it REALLY WORKS. In fact, if you use it, use it very lightly, like half the supplied amount. The whole bottle on a 25 X 22 garage made the floor like sandpaper. You will not slip, but it hurts the knees while kneeling. I like the finish, as during the winter ice will drop off the car and get the foor wet, so you really need some type of anti-slip properties. Also the squeege that I bought to help scrub the floor clean, doesn't work well after applying the anti-skid stuff.
I know this reply has some negatives, but it could have been my fault in the application, and I firmly believe that there is some grease that you can never get up, and on a floor this old, I could not get all of the floor to not "bead" when wetting during cleaning. NO paint, epoxy, urethane, glue or anything will stick to a greasy floor.
If you have ever used Armorall or any stuff that has silicone in it, you won't get anything to REALLY stick to the floor. I use armorall on my tires outside in the driveway, and the armorall spots on the ground don't even get wet in a hard rain.
The water based epoxy is very convenient for clean-up of brushes and rollers, and for splatters etc. Also no smell or solvents to evaporate.
I like my garage floor. Here's a pic. More pics on my website link to site
It is incredible, no lifting. The epoxy to concrete bond is greater than the internal bond of the concrete. The only place where there is missing paint, there is missing concrete. This only comes from dropping air tools, jack stands, etc.
I give it a coat of wax once or twice a year to reduce tire staining and improve clean ability. I clean most stains with scotchbrite and finish with wax. It is 8+ years and still gets compliments.
[Modified by C5 Tweaker, 8:15 PM 10/25/2001]
Floor is from Motormat http://www.motormat.com
Cost a little over $1000 shipped for my 2 car garage.
More info and pics............ http://home.att.net/~jansseng/Garage.htm
[Modified by Black_Magic, 8:03 AM 10/26/2001]
I thought about using the motormat but I'm concerned about cleaning up spills. Doesn't whatever gets splilled just make it's way down to the concrete? Then wouldn't you have to lift the mat to clean under it? Or, do they make a solid motormat?
Thanks,
[Modified by tfinzel, 3:09 PM 10/26/2001]
The web address below has some pics of my current garage.
http://temp.corvetteforum.net/c5/jsc...e_My_Car.shtml
