Power seats (memory)
Old Jun 8, 2007 | 08:34 PM
C5 Pat's Avatar
C5 Pat
Default Power seats (memory)
Hey People
Just got my 02 I,m a first time Vette owner, 52 yrs. old can you believe it! Has anybody had trouble with the memory seats? Mine works sometimes but other times it stays in the easy entry position and won't move even manually.I shut the easy entry option off but it still goes back when you leave the car. Need help ......Thanks ..Pat
Old Jun 8, 2007 | 09:01 PM
Roadsho's Avatar
Roadsho
Cruising
Hey Pat,
Congratulations on the purchase. I just bought my 02 in January when I turned 50. Love it. But, as you indicated I also have a memory seat position glitch. Every once in awhile the seat won't go into the auto memory. I find myself needing to put it in park and push the number one position setting to reset. My headlight covers also pop up when I turn on my parking lamps on. Oh well, just electrical ghost I guess.
Best of luck with the car.
Old Jun 8, 2007 | 09:07 PM
C5 Pat's Avatar
C5 Pat
Thanks Man, Your never too old!! .....Pat
Old Jun 8, 2007 | 11:12 PM
flexvette's Avatar
flexvette
Default memory seats
My o3 coupe needs to have the security system engaged and disengaged or I have to manually set the memory button. I believe this correct functioning.
Old Jun 16, 2007 | 12:31 PM
C5 Pat's Avatar
C5 Pat
Thanks Man, I will try that
Old Jun 18, 2007 | 07:19 AM
cenzo's Avatar
cenzo
Originally Posted by C5 Pat
Hey People
Seat memory is activated when you push the "unlock" button on the keyfob as you enter. If you didn't need to unlock the car, you'll have to push the memory button on the door to activate.
Old Jun 18, 2007 | 08:15 AM
kvozel's Avatar
kvozel
From: Centerville OH "If we weren't all crazy we would go insane"
CI 3-4-5-6-7 & 9 Veteran
St. Jude Donor '08
Old Jun 18, 2007 | 11:27 AM
dgrant3830's Avatar
dgrant3830
Wounded Warrior Escort '11
Seems to be a lot of this happening lately. I will suggest that you look into the driver's seat connectors that connect to the car. One of which on my '99 is a 7-pin connector. That connector (on mine) is the problem child. Clean those contacts carefully and I think your problem will be solved.
Old Jun 18, 2007 | 09:57 PM
C5 Pat's Avatar
C5 Pat
I think the connector may be dirty because sometimes (rarely) the seat dosen't want to move at all another job on the todo list..Thanks People.....Pat
Old Jun 18, 2007 | 10:45 PM
01NBMC5's Avatar
01NBMC5
Hey People
Pat,
Welcome to the forum. I got my first Vette last year and I'm 64. This is a great place for info. So far I replaced a door control module, fixed a rocking driver's seat and installed the Frost King insulation.
Roger
Old Jun 24, 2007 | 12:59 PM
C5 Pat's Avatar
C5 Pat
Originally Posted by 01NBMC5
Pat,
Roger
Is that the Headlight door your talking about, if it is read my post this morning and let me know if the problem is similar..Thanks Pat
Old Jun 24, 2007 | 03:57 PM
GONZZO's Avatar
GONZZO
Congrats
I have an 04 Z06 that has the same problem, I found that there is a connector in the accordian boot between the body and the door, the electrical contacts in the connector loosen from the opening and closing of the door if you hit the accordian you can feel the electical connector and sometimes this is enough for every thing to go back to normal, you may encounter as I have nothing works in the door at all locks window memory function once again it is the electrical connection. I have yet to remove the connector and put the wires together in another fashion.
Good Luck and many happy miles
Pat
Old Jun 26, 2007 | 09:04 PM
C5 Pat's Avatar
C5 Pat
Everything else works so I'm kinda looking at the switch. I will have a look at the wirering in the door as well...Thanks
To Power seats (memory)
