Ls1 Ls6
Old Jun 9, 2007 | 07:09 PM
rbrtclk's Avatar
rbrtclk
Default Ls1 Ls6
Will the heads from an LS6 fit a LS1? If so, what is the expected HP gain?
Old Jun 9, 2007 | 08:25 PM
82shark's Avatar
82shark
Default Yes
Getting ready for a head/cam job with the same heads (out of an LS2, same as the z06) and a more aggressive cam
Old Jun 10, 2007 | 12:38 AM
jeanlucpicard's Avatar
jeanlucpicard
Yes, the LS-6 heads will will fit but why bother? The gains are going to be minimal and considering the work involved you really should consider a full H/C package upgrade. When you change out the heads you should also install new hydraulic lifters and cups and, depending on the mileage, you should install a new oil pump and water pump as a minimum. Remember, heads that have been ported breathe better but it is the cam that regulates valve opening / timing and that is where the HP comes from. Also, if you do a H/C package you will definitely need to consider long tube headers and possbily a different intake and throttle body to open up the intake and exhaust so the car can grab all the new HP.
Old Jun 10, 2007 | 12:09 PM
rbrtclk's Avatar
rbrtclk
thanks for the info.
To Ls1 Ls6
