How do I gets up front susp?
Old Jun 9, 2007 | 11:45 PM
RogerArrambide's Avatar
RogerArrambide
Default How do I gets up front susp?
My car appears to be lowered about 1 or 2 inch...
The hit too much I Mean, my garage is a little bit up than the street and the car hits the entrance.
I need to upper the front of the car.. some body told me that is easy, but I dont know how.
Old Jun 9, 2007 | 11:59 PM
chris308's Avatar
chris308
do this in reverse...
https://www.corvetteforum.com/techti...D=27&TopicID=1
Old Jun 10, 2007 | 12:19 AM
jeanlucpicard's Avatar
jeanlucpicard
Are you sure you are not dragging the small black plastic air lip under the front facia when going in and out of your driveway? I drag mine all the time and simply replace the piece every couple of years for $50 and an hour of my time - plus beer breaks Raising and lowering the front and rear of the car is a piece of cake but you will need a couple of jacks - one to lift the car and another to lift each wheel to take tension off the bow spring so you can turn the bolt.
Old Jun 10, 2007 | 01:09 PM
RogerArrambide
Thanks both for understand my bad english because my born language is spanish, so I do my best...
Well, that you said Mr Entreprise captain , my car doesnt have that plastic , only the middle one, on the other side, I tried to use an antique type of meassure....... insert the hand between the tire and the fender of my friend´s Z06 and I can insert 4 fingers between them and the bottom of the bumper where at high as my ankle 1 inch up.....
When I did that in my Vette, I only can inserted 2 or maybe 2 and a half and the bumper are exactly in my ankle....
I have enough tools to do the work, so I will try..
I´ll let you know the result.
Thanks again
Old Jun 10, 2007 | 01:24 PM
BanditDude's Avatar
BanditDude
Thanks again
You'll also need to get an alignment when you've finished. Good luck!
Old Jun 10, 2007 | 01:32 PM
RogerArrambide
Ok, perfect!!
thanks
To How do I gets up front susp?
