Help with crank bolt removal
Old Jun 10, 2007 | 01:45 PM
southernshark's Avatar
southernshark
Default Help with crank bolt removal
any tips. i have a 600 ft lb impact that wont budge the bolt and ive been after it with a 4 ft cheater bar. any tips would help my forearms feel like they are going to blow up.
Old Jun 10, 2007 | 02:02 PM
tellefan's Avatar
tellefan
I've never removed one. However is this a reverse thread bolt? David
Old Jun 10, 2007 | 02:09 PM
southernshark
...dear god i hope not...any one know for sure. i gussed it was regualr
Old Jun 10, 2007 | 02:20 PM
SteveDoten's Avatar
SteveDoten
Cruise-In VII Veteran
it is not a rev/lefthand thread bolt
your impact may be a bit tired, try a few drops of oil in the air fitting and make sure your pressure is up on the compressor
Old Jun 10, 2007 | 02:25 PM
Vegas Vette's Avatar
Vegas Vette
As Steve said it is not a Rev/Bolt but you do need to take a small torch and heat the bolt head up pretty good to melt the lock tight and it should come right out. Dont ask how I know this
Old Jun 10, 2007 | 02:52 PM
southernshark
looks like heat will be next. i've got ps. fluid on some things so ill have to do alot of cleaning first.
Old Jun 10, 2007 | 03:55 PM
southernshark
thanks took the torch to it and a little bit of cheater bar and came off.
thanks again C.F.
Old Jun 10, 2007 | 04:25 PM
Vegas Vette
thanks again C.F.
To Help with crank bolt removal
