Meziere wiring help needed
Old Jun 10, 2007 | 03:27 PM
zeevette's Avatar
zeevette
Default Meziere wiring help needed
This is really stupid, but I'm stuck on a simple thing. I need to find a "trigger" wire under the fuse block, that's powered only with the ignition ON, or even better, with the fuel pump. I've spliced into three wires already, using instructions from ls1howto, and so far, all 3 have been hot when the key's not even on. I'm using a multi-tester to sample the wires, but 0 for 3 seems like I'm doing something wrong. Any advice?
