Fuel injectors?
Old Jun 10, 2007 | 06:54 PM
NightmareZ06's Avatar
NightmareZ06
Default Fuel injectors?
I know that this may end up being another " mine are better then yours" thread but i am looking around at fuel injectors for my 02 Z and am not sure which ones to go with. I belie ve the factorys are 28# so im looking towards 38#. What do you guys think.....thanks, nightmarez06
Old Jun 10, 2007 | 07:09 PM
robsciam's Avatar
robsciam
do you have more mods ahead?
Old Jun 11, 2007 | 02:53 AM
thetorch's Avatar
thetorch
The FAST 36 lbs. injectors would suit you just fine. They are the latest generation Bosch design that employs a stronger coil for faster response. They also benefit from a better spray pattern than the previous Bosch designs. They can be found for ~$300 to the door.
Remember that you will end up with a larger injector because of the 58 lb. fuel pressure on the LS cars.
Old Jun 14, 2007 | 09:22 PM
NightmareZ06
alrite thanks, what kind of injectors are to be the best, bosch, delphi,accel,etc. and where can i get them. any websits....thanks guys!!!
BTW i should be around 600flywheel horse by the winter so i guess ill need around 42#ers.....if bosch are one of the best, where can i buy them?????
Old Jun 14, 2007 | 09:34 PM
OMG its Jason's Avatar
OMG its Jason
I have a post on this as well.
Where is the best place to get these from?
approximately what kind of MPG should you expect to lose?
Has anyone actually done a comparison with dyno's "before after fuel injectors with 420+rwhp".
Maybe I should do a search first.
Old Jun 16, 2007 | 12:30 PM
NightmareZ06
You cant tell me that nobody knows about fuel injectors. Little help please.....thanks guys
Old Jun 16, 2007 | 03:25 PM
thetorch's Avatar
thetorch
I would stay away from Accel injectors; based on flow testing I've had done on two different sets of Accel injectors, the results were less then stellar.
For 600 HP at .5 BSFC with 85% duty cycle, a 44 lb @ 43.5psi static injector flow rate would be the correct size. Adjust injector flow rate according to actual fuel pressure.
I have had good luck with the FAST 36lb injector, which is a Bosch 0 280 155 868. The FAST/Comp Cams part number for an 8 pack is 303608. I have purchased two sets from a guy on ebay for ~$300 shipped.
The part number for the FAST 42lb injector is 304208 and is Bosch 0 280 150 558. Flow information http://www.witchhunter.com/flowdatapix/b0280150558.jpg
HTH,
Old Jun 19, 2007 | 05:29 PM
NightmareZ06
HTH,
Thanks alot, i appreciate it very much!!!
To Fuel injectors?
