Problem
Old Jun 11, 2007 | 09:08 AM
whitesnake81's Avatar
whitesnake81
Default Problem
I have two problems I hope someone can help me with. (1) The Oil presure gage goes all the way over to 80 pounds when the motor is running and back to 0 when not running. (2) The Memory for the seats has quit working. The light in the door comes on , but the seats do not operate. THANKS FOR ANY HELP!!
Old Jun 11, 2007 | 09:26 AM
Bill Dearborn's Avatar
Bill Dearborn
Have you accessed the On Board Diagnostics and seen what codes are showing? To get the codes turn on the ignition (do not start the engine), press and hold the options button and press the fuel button 4 times. Write down the letters and numbers for each code shown as the diagnostics goes through each system on the car.
Bill
Old Jun 11, 2007 | 09:56 AM
rws.1's Avatar
rws.1
the oil pressure sensor is sot.. it needs replacement....
here is the best fix document on the forum
http://forums.corvetteforum.com/show...ressure+sensor
here is a sticky on relocations
http://forums.corvetteforum.com/show....php?t=1588172
Old Jun 11, 2007 | 10:03 AM
whitesnake81
Default Problems
Bill
THANKS VERY MUCH!!
whitesnake81
THANKS VERY MUCH!!
To Problem
