Gas gauge broke?
Old Jun 12, 2007 | 12:18 PM
ajordan620's Avatar
ajordan620
Cruising
Default Gas gauge broke?
I have a 2001, auto, with 74K miles.
I had just over a 1/4 of a tank of gas when I went to sleep last night, and when I cranked the car up this morning it said "Low Fuel." Put gas in it this morning, and the needle didn't budge. And it keeps saying "Low Fuel." What could be the cause?!
Old Jun 12, 2007 | 12:22 PM
VLVETTE's Avatar
VLVETTE
Do a search on the gas gauge issue it is well known. Sometimes it can be fixed by running some Techron fuel additive through your system. The main reason for the malfunction is a build up on the fuel sensors
Old Jun 12, 2007 | 12:32 PM
Last C5's Avatar
Last C5
My 2001 Z has the same problem and I keep it in check with a periodic diet of Techron and trying to keep at least half a tank in it.
Old Jun 12, 2007 | 01:08 PM
Nyvetteguy007's Avatar
Nyvetteguy007
Plenty has been written on the subject..
I had the same issue, try 1 techron bottle when you fill up ur tank...(20 gal treatment) if it doesnt clear it up, do it again the next fill up, you should be OK unless there is truly a mechanical issue...
I did the above and now use techron every 3-4 tanks of gas, not an issue since...hth
Old Jun 12, 2007 | 01:29 PM
Corvette Don's Avatar
Corvette Don
Sea foam in the gas tank with about 6 or 7 gallons in it (under half tank will work too), did that and has worked ever since (7 months ago)
Old Jun 12, 2007 | 02:03 PM
ajordan620's Avatar
ajordan620
Cruising
Thank you for all your help!!!
Old Jun 12, 2007 | 11:42 PM
strauser's Avatar
strauser
So I have seen this on my vehicle and am convinced it is a pin/socket corrosion issue on the connector. Try cleaning contacts with a brass wire brush...worked for me.
To Gas gauge broke?
