Rotor question. Need help please
Old Jun 13, 2007 | 10:39 PM
tripod5's Avatar
tripod5
Default Rotor question. Need help please
It's time to change my brakes and decided instead of turning down the rotors, i would just get new ones. My question is when i went to my local autoparts store, the man there told me that the front left rotor and the front right rotor are different. Is this correct, or does this guy not know what he's talking about. Thanks in advance.
Old Jun 13, 2007 | 10:48 PM
tiojames's Avatar
tiojames
From the posts here Napa is the best and cheapest source for vette rotors. The cooling vanes face opposite directions, so yes there is a difference in the front rotors side to side.
Old Jun 13, 2007 | 10:50 PM
Rickyh93's Avatar
Rickyh93
I believe they are different. The vents in the rotors go one way toward the back I believe(that was the way my old rotors were). I don't have my reciept but I'm almost positive mine had different part numbers. I got mine from Napa $28/each
Ricky
Old Jun 14, 2007 | 12:14 AM
rws.1's Avatar
rws.1
As mentioned above, the vanes face the rear on all stock replacement rotors....
therefore each of the 4 rotors is a unique part.
Old Jun 14, 2007 | 01:21 AM
RoccoC5's Avatar
RoccoC5
I recently replaced mine with GMPP drilled/slotted rotors and ceramic pads and love them! Increased stopping power and little to no brake dust! Got everything from a dealer on eBay for around 300...
Old Jun 14, 2007 | 10:45 AM
tripod5's Avatar
tripod5
Thanks for all the replies everyone. Now i know every rotor is different.
Old Jun 14, 2007 | 12:31 PM
MattB's Avatar
MattB
More than just the vanes, the rears have the parking brake in them as well which is a small drum.
Good luck with the change, there are a couple of good write ups around here if you search.
Old Jun 14, 2007 | 04:49 PM
bighank's Avatar
bighank
Default Gm Rotors
Got my OEM GM Rotors for $22.80 at GM parts wholesaler (sells AC DELCO parts to dealers). Don't get some EL CHEAPO if you can get the real thing for equal or less money.
Only put new ones on the front... the rears were fine but pulled em and set the P B starwheels so the car COULD be held by the PB. BIGHANK
Old Jun 14, 2007 | 06:22 PM
Bill Dearborn's Avatar
Bill Dearborn
Tripod5,
The rotors do not need to be turned when doing a pad replacement. If the pads haven't scored the rotors and the rotors are not worn to thin there is no reason why you should replace them or turn them.
Bill
To Rotor question. Need help please
